Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Suspension
Suspension 1st Gen Dodge Ram Suspension Problems and Questions
Old 03-07-2013, 05:31 PM
skote888 skote888 is offline
Vehicle: 1989 W150
Trim Level: Base
Color: Grey
Engine: 1989-1992 360ci (5.9L) LA V8 190hp
skote888 is on a distinguished road
Default 35's on my stock ram
Hey,
Just wondering if its possible to put 35x12.5's onto my stock 89 ram W150. Its got the stock lift and 31x10.5's on it right now. I cant seem to find a straight answer online or from friends. Some say i just need a wheel spacer others say a 2" lift. Any experience from you guys?
Scott
Old 03-07-2013, 05:54 PM
crazzywolfie crazzywolfie is offline
Vehicle: 81 91 93 dodge
crazzywolfie is on a distinguished road
you need at least a 2" lift to fit 35" tire. if you plan of taking it off road you may want at least 4" lift or you end up having tires come in contact with the wheel wells. it is probably also not a wise idea to be running 35" tires with the stock gears. most trucks came from the factory with 3.55 gears which is ok for turning the stock 31's but with 35's and stock gears will put a lot of stress on things and you may end up breaking things like drive shafts or axles.
on another note did you use to own a 91 Dakota - 3.9 - 5 speed - 2 wheel drive and 81 Dodge power Ram - 360- Four on the floor?
91 & 81 d150 carburated 318's 93 R.C. F.I.318
Old 03-07-2013, 10:21 PM
Vehicle: 1989 W150
Trim Level: Base
Color: Grey
Yeah I owned the Dakota up till a year and a half ago or so and I did have a white 81 4x4 for a while yeah
Scott
Old 03-07-2013, 11:03 PM
that would be why i recognized the used name. you asked a similar question on dodge forum a while ago. you wanted to know if you could fit 31's on your 81.
Old 03-12-2013, 01:25 PM
Vehicle: 1989 W150
Trim Level: Base
Color: Grey
must have been quite a while ago, i dont even remember doing it. Yeah that poor ol truck didnt end up working out. In the end it made a pretty good truck box trailer though.
