6" Lift, Total height of Truck - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 03-08-2013, 07:58 PM
ziechman ziechman is offline
Vehicle: 2011 Dodge Ram 1500
Color: Hunter Green Pearl
Rep:13
ziechman is on a distinguished road
Default 6" Lift, Total height of Truck
Hey guys, looking into the various 6" lifts and probably 35" tires on 20x9 fuel wheels and was wondering if you all could post how tall your truck is. Please include your setup, what lift, tire/wheels, shocks. Basically, truck needs to fit into my garage otherwise this is a no go and I will be slapping the bilsteins on with a rear spacer and going that route. I have 82" of clearance to stuff the truck in so please give me some good news. Thanks in advance gents.
18" Magnaflow True Duals, Tru-X Crossover, S&B CAI, Diablo T-1000, Billet Technology Catch Can and Shifter Ball
Old 03-08-2013, 08:30 PM
Ram725's Avatar
Ram725 Ram725 is offline
Vehicle: 2012 Ram 2500 4x4
Rep:347
Well I guess it wont do you any good for me to post pics... I doubt mine would be even close to fitting. I don't know many guys on here running the 6" on 35s. I can think of one or two. Maybe they will chime in here.
Good luck. Hope it works out for you
Build Thread
SOLD: 2012 Ram 2500 CTD 4x4
Old 03-09-2013, 01:19 PM
Rep:13
Just for now I decided to pull the trigger on the bilsteins and start with just leveling the truck first. Want to say thanks to discount performance auto for all the help. Great guys to deal with and very helpful. Also went with the Diablo t-1000. Still would like some input on the height of you guys setups even if you are running larger than 35's. The tire size should be pretty easy to subtract down to what I want to buy.
Old 03-09-2013, 03:38 PM
MTtruckr's Avatar
MTtruckr MTtruckr is offline
Vehicle: 2009 Ram 5.7L
Trim Level: Big Horn Package
Color: Stone White
Rep:50
MTtruckr will become famous soon enough
You're going to be close. I measure about 81 to 82 inches to my highest point. I have the BDS 6 inch with no extra level up front, but I only have about a half inch or so rake on mine.
I'm running Toyo MT 35's which on the truck are not a true 35, more like a 34.5, at most.
BDS 6 inch. Fox 2.0 rear. Toyo MT 35x12.50x18. Yukon 4.56's. Detroit Truetrac. Mufflex 18. Airaid CAI.
Old 03-10-2013, 07:43 PM
fastNugly @ RP's Avatar
Revel Performance
Rep:1804
My garage is 83"
My truck fits into my garage height wise (length wise is another story)
I have a 6" RCX and Bilsteins at 1.4" and a 1" rear coil spacer on 35's
My truck measures at 82.5" at the sat/nav antenna
Now, RCX is 1/2" taller of a lift than other kits....
So if you go RCX, you will need to set your bilsteins at 0.7 and run no rear coil spacer.
Otherwise, you can run a different kit BDS/Zone/Pro Comp and set the Bilsteins at 1.4"
sales@revelperformance.com
Old 03-11-2013, 08:02 AM
Rep:13
Thanks as alway fast. Very helpful info. Don't think I need a rear coil spacer anyways. The rear is about 3.25" taller than the front as is stock right now. Don't remember, what 35's are you running for winter right now?
Old 03-11-2013, 08:19 AM
aedwardzo aedwardzo is offline
Vehicle: 2009 Dodge Ram
Color: Light Graystone
Rep:57
aedwardzo will become famous soon enough
I believe he is running some Nitto terras if im not mistaken...
mods..... Too much to list! check my mod list!
http://www.ramforumz.com/member.php?u=58666
Old 03-11-2013, 10:04 AM
Revel Performance
Rep:1804
You got the higher of the rake avg.
Yes, you will not need it.
Nitto Terra as aedwardzo mentioned below
Thanks, you are correct
Old 03-11-2013, 11:01 AM
Revel Performance's Avatar
REVEL PERFORMANCE
Vehicle: MOPAR
Rep:931
No problem at all, if there is anything else we can help you out with in the future feel free to reach out to either myself or Andrew we would be more than happy to assist you
Thanks
Jeremiah
Discount Auto Performance
