Conversion: Center Console to Column Shift - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Body & Interior
Old 03-09-2013, 01:07 PM
ironchef2011's Avatar
ironchef2011 ironchef2011 is offline
Vehicle: 2012 R/T
Trim Level: R/T
Rep:120
ironchef2011 will become famous soon enoughironchef2011 will become famous soon enough
Default Conversion: Center Console to Column Shift
Most people convert the other way but I actually prefer having the additional seat and a shifter on the column. So here is a detailed list of the parts required to convert my 2012 Dodge Ram regular cab and some pictures and observations as well. Please note that the parts listed below are the black/slate grey coloring.
Parts Required:
  • Radio Bezel (w/115v outlet)- 1KZ311SDAC
  • Radio Bezel (w/o 115v outlet)- 1EB041SDAC
  • Cupholder- 1EA971DVAI
  • Right Side Panel (w/12v outlet)- 1HR95XDVAB
  • Left Side Panel (w/12v outlet)- 1HR94XDVAB
  • Closeout Panel- 1EB14XDVAA
  • Shift Cable- 68092061AB
  • Cable Bracket- 68042294AA
  • Lever- 68092747AA
  • Shifter Assembly- 5057536AD
  • Column Shroud- 1GD32XDVAB
  • Retractable Center Seatbelt Assembly-
  • Center Seat- **Find one on EBay or CL as these are mad expensive new**
The key here is that everything is a very easy switchover. Here are the steps:
Removal:
  • Remove Center Console
  • Unplug and Detach Shifter Assembly
  • Remove Radio Bezel
  • Remove Plastic Column Shroud (behind steering wheel)
  • Remove Shifter Jump Harness (extension wire from main wiring harness)
  • Remove Shift Cable and Mounting
  • Remove All Switches from Radio Bezel
  • Remove Rear Cab Panel
Install:
  • Install Switches to New Radio Bezel
  • Install New Radio Bezel
  • Install Cupholder
  • Install Side Panels
  • Install Bottom Closeout Panel
  • Install Column Shift Assembly
  • Install New Shift Cable and Bracketry
  • Install Seat Belt Assembly
  • Install Rear Cab Panel
  • Install Center Seat (make sure you get it with the two brackets that mount to the passenger seat, bolts/nuts and the two seat belt buckles)
After this my friends, you are done! The carpeting is the same so no need for any customization whatsoever. The center seat mounts right up, the rear cab panel has all the mount provisions for the seatbelt assembly and is ready to go as well. You do NOT need a new steering column either as some have noted. All in, this seems complex but can be done in a day easy. The hard part was tracking down all of the correct parts to do this properly! That being said, I want to give a HUGE shoutout to Benny at MOPARPARTSONLINE!
2012 R/T 392
Old 03-09-2013, 01:08 PM
Vehicle: 2012 R/T
Trim Level: R/T
Rep:120
Here's some finished pics prior to the column shifter install......
2012 R/T 392
Old 03-09-2013, 02:44 PM
Chris b's Avatar
Chris b Chris b is offline
Vehicle: 2012 RAM
Trim Level: R/T
Rep:312
glad you got it worked out friend. waiting on pics.
SPONSORED BY
BULLY'S PERFORMANCE
Old 03-09-2013, 05:16 PM
Rambabe Rambabe is offline
Vehicle: 2005 Dodge Ram
Rambabe is on a distinguished road
Thanks so very much for posting this. The center console is the reason I've not yet purchased a new Ram. I mean seriously, who wants to have their right leg rubbin' up against a plastic box with a silly automatic shifter stickin' out? Looking forward to the pics, and thanks again!
Old 03-09-2013, 08:17 PM
Vehicle: 2012 R/T
Trim Level: R/T
Rep:120
I couldn't agree more!
2012 R/T 392
Old 03-10-2013, 11:32 PM
Chris b's Avatar
Vehicle: 2012 RAM
Trim Level: R/T
Rep:312
so where's the shifter???
SPONSORED BY
BULLY'S PERFORMANCE
Old 03-11-2013, 06:35 AM
Vehicle: 2012 R/T
Trim Level: R/T
Rep:120
In those pics, it's on the floor by the drivers seat temporarily. This allowed me to complete the console and seat while I waited for the parts to arrive for the column. Now, the shifter is on the column just like any other Ram.
2012 R/T 392
Old 03-11-2013, 07:04 AM
rango88's Avatar
rango88 rango88 is offline
Vehicle: 2011 Dodge Ram 1500
Rep:18
rango88 is on a distinguished road
Good write up
Andy ***Cannot see all Pics and Videos***
Old 03-16-2013, 12:00 PM
TriSum's Avatar
TriSum TriSum is offline
Vehicle: 2012 Ram R/T
Trim Level: R/T
Rep:47
TriSum is on a distinguished road
Thanks for the write up. I'm not sure how long I will keep mine either, it is just too big and kills all the interior space.
David
2012 R/T
ARH Longtubes, Diablo Trinity, Flowmaster, Belltech 2"/4" Lowering Kit, Spohn Track Bar, Hellwig Sway Bars, QA1 Double Adj Shocks, Bak Flip "VP" Tonneau Cover, Oil Catch Can, Rear Air Bags
Old 03-16-2013, 05:04 PM
Vehicle: 2012 R/T
Trim Level: R/T
Rep:120
I couldn't agree more. And after some time with the column shift setup, it's simply perfect. I've been able to haul more inside, have both my daughters with me, and best of all, the whole cab just feels roomier. I've never liked center consoles that link up with the dash as they are simply space killers.
2012 R/T 392
