Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > LD RAM - General Discussion
LD RAM - General Discussion RAM 1500 General Chat. Please post your tech questions in the HELP Zone!
Old 03-09-2013, 05:16 PM
Rob Swain Rob Swain is offline
Vehicle: 1998 Dodge Ram 3500
Trim Level: Base
Engine: 1996-1998 359ci (5.9L) Cummins 12-valve Diesel I6 215hp 440lb/ft(manual), 180hp 420lb/ft(auto)
Rob Swain is on a distinguished road
Default Brake Shudder
I have 1998 Dodge Ram 3500 Dually. Took the truck in to the shop last year, because of what I thought was a "Clunk" in the rear end. They opened the rear end, everything was fine.Turns out it was a loose wheel. Two rims needed to be replaced and wheel studs ( both sides had studs replaced). Picked up the truck, applied brakes when turning into my driveway, then had very bad brake shudder. Returned to shop, they checked front and back brakes, everything looked good, they went as far as turning the back drums. Problem persisted, then I found out I had a puncture in one of the rear Duallys, repaired with big improvement, however it has returned, I even replaced the rear shoes. Could this be an ABS problem?
Thanks!
Old 03-10-2013, 05:08 PM
Outlaw's Avatar
Outlaw Outlaw is offline
Vehicle: 2014 Ram 1500 RCSB
Color: Bright white
Rep:435
Outlaw is just really niceOutlaw is just really niceOutlaw is just really niceOutlaw is just really niceOutlaw is just really nice
Check the front brake rotors. Prolly warped
[CENTER][SIZE="4"][COLOR="green"]2014 RAM 1500 RCSB BRIGHT WHITE[/SIZE][/COLOR]
[/CENTER]
