Old 03-09-2013, 10:25 PM
RammD RammD is offline
Vehicle: 2010 RAM SLT REG. CABX2
Color: CRYSTAL BLACK PEARL
Rep:61
RammD will become famous soon enough
Default Vehicle Security Indicator Warning light going off (Red Dot)
I noticed yesterday that a red light which looks like a red dot on my gauge cluster to the lower right was on solid. I've never seen that light on before so I checked the Owner's Manual and it says that's the "Vehicle Security Indicator." It doesn't say much more then that. Can anyone who has had this light come on or is familiar with what I should be looking for in order to trouble shoot? I can't see or feel any noticeable issues with the truck. Any info would be much appreciated. Thanks in advance.
Old 03-10-2013, 12:09 AM
bran101010 bran101010 is offline
Vehicle: 2011 dodge ram 1500
Trim Level: express
Color: silver
bran101010 is on a distinguished road
When my wife had her jeep srt8,when that lit up her battery went dead a couple days later.Could maybe have something to do with the alarm system built into the vehicle too.
Old 03-10-2013, 12:41 AM
Rep:61
Hey Bran,
thanks for the response. I checked the battery and the voltage appears to be excellent. The alarm system is working flawlessly as well. HOWEVER, I did notice when I went to check my tire pressure that there are dashes "-" in each of the 4 slots where the tire pressure should be so my tire pressure monitoring system is not registering correctly. Would that security indicator light come on for the tire pressure system acting faulty?
The odd part about all this is that I posted a thread last week about my tire pressure system acting a little funky but it turned out I had TWO TIRES losing air pressure...1 from a nail and the other from a piece of metal that pierced through the tire. It was a total coincidence, but I got both tires repaired and all has been fine since...until now that is with the security indicator light issue. I wonder if both of those tires losing pressure could of caused some kind of glitch or malfunction and if maybe I should disconnect the battery and try to reset the system?
I don't know if the issues are related but the tire pressure system did act a little weird during the time I was losing air pressure in the tires. However, after I got the tires repaired, I checked for a week straight and the tire pressure was perfectly accurate the entire time. If anyone else can chime in and offer any advice, it's definitely welcome and would be appreciated.
Old 03-11-2013, 02:39 AM
Rep:61
anyone have any ideas?
Old 03-11-2013, 07:39 AM
rdsabin rdsabin is offline
Vehicle: 2012 Sport Reg Cab 4x4
Trim Level: Sport Reg Cab
Color: Mineral Gray Metallic
Rep:186
rdsabin has a spectacular aura aboutrdsabin has a spectacular aura about
When you lock your vehicle with the remote it engages the alarm and the red light will flash fast for about 15 seconds. Then it will start flashing very slowly to show the system is armed. To disarm it you need to open the door with the remote or put the fob in the ignition. If you use the key to open the door and alarm is on it will go off. Only way I know of to make it quit honking and flashing lights is to hit unlock button or insert for into ignition.
I would sit in the vehicle and arm the lock with the remote and watch to light for about 1 minute to see if it does flash fast first then slowly. If it does it is working fine. If it doesn't then take it in and have dealer look at it.
2012 DodgeRam 1500 4x4, 20% Tint, Running Boards, Class IV Hitch, 14" Win Muffler, Catch-Can, Tow-Hooks, LED Tailgate Bar
2008 Dodge Supe Bee, Catch Can, Backup Camera, 20% Tint all windows, CAI, AFE Filter
Old 03-11-2013, 08:49 AM
JimsRamTruck2012's Avatar
Vehicle: 2012 Ram Express
Trim Level: Express Package
Color: Mineral Gray Matalic
Rep:320
Have you tried using the other key fob? It maybe that the battery in the one you are using is weak.
If using the other fob doesn't solve the problem take the truck to the dealership and have them check the vats. That is the general term for the security program. There maybe a glitch in it.
Old 03-11-2013, 01:22 PM
Rep:61
Thank you for the replies. I should mention that the yellow warning exclamation light is also on and solid and as mentioned my TPMS is not registering at all. There are Dashes where the tire pressure number would normally be so the tire pressure system is not operating. The yellow exclamation light and vehicle security light are both on and solid while driving. These issues both occurred (red light and yellow light) at the same time so could it be possible there's an electrical system malfunction?
Old 03-11-2013, 04:26 PM
SFVDOC's Avatar
SFVDOC SFVDOC is offline
Vehicle: 2012 Ram 1500 CC 4X4
Rep:83
SFVDOC will become famous soon enough
Disconnect the vehicle battery. Wait 15 minutes or so and reconnect. That might clear up any funk that's going on.
Old 03-11-2013, 04:54 PM
Rep:320
that would be another good step to take.
From your recent post RammD is sounds like the pcm isn't booting up correctly upon starting the truck.
Old 03-11-2013, 05:25 PM
Rep:61
Thanks again. I wrote in my second post maybe I should try to disconnect the battery....since you think that may work and it can't hurt I'm gonna do that tonight. I have a feeling I may know the issue and I think it could be related to one of my hid capacitors. I could be wrong but I'm gonna test something and find out and report back.
