tonneaucovered.com
Old 03-10-2013, 12:03 PM
2010hemi143 2010hemi143 is offline
Vehicle: 2010 dodge RAM
Color: blue
2010hemi143 is on a distinguished road
Default where can i find a 8 inch lift or higher for my 2010 1500??
just wondering if anyone could help me out trying to find a lift kit 8 inch or bigger for my hemi
Old 03-10-2013, 12:32 PM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
all the guys running that high or higher are running a 6" with a body lift and some other spacers/bilsteins. I've never seen a straight 8" lift. but u can add things to get up there
Old 03-10-2013, 12:57 PM
Revel Performance's Avatar
REVEL PERFORMANCE
Vehicle: MOPAR
Rep:931
for this I would recommend to you either a 6" suspension and a 3" body for a total of 9", or a 6" with bilsteins set to 2.1 or 2.4 or procomp zx2014 shocks set to 2.75", or if you want to get real crazy you could do a 6" suspension with bilsteins or procomp zx2014's and a 3" body lift, if you would like I could put a quote together for you all I would need is your zipcode and which combo you wanted to do.
Thanks
Jeremiah
Discount Auto Performance
sales@revelperformance.com
Old 03-10-2013, 01:35 PM
Color: blue
alright thanks for the advice, just wasnt sure if it was the only option to go with the 6 inch, not a body lift type person but im gonna have to be if i want her higher then 6!
Old 03-10-2013, 01:53 PM
REVEL PERFORMANCE
Vehicle: MOPAR
Rep:931
You do not have to do a body lift to get higher than 6" but you do have to add other parts, if you add bilsteins adjustable shocks or procomp adjustable shocks you can go up another 2.75" on top of the 6" lift however you would also require a rear coil spacer to keep from looking nose high.
For example our company vehicle is configured like this
6" procomp stage 1 lift kit
procomp prorunner zx2014 adjustable shocks set to 2.75" in the front
procomp prorunner zx2001 shocks in the rear
ready lift 1.75" rear coil spacer.
for a total of 8" suspension lift.
hope this info help you out, the only reason to use a body lift would be to go bigger than 8" but you can for sure get to 8" without using a body lift.
Thanks
Jeremiah
