tonneaucovered.com
Old 03-11-2013, 04:01 PM
Bpalmer22's Avatar
Bpalmer22 Bpalmer22 is offline
Vehicle: 09 Ram 1500
Color: Gray
Rep:42
Bpalmer22 is on a distinguished road
Default Penetrating oils
borrowed from damnriders.org
Machinists Workshop Mag™ recently published some information on various penetrating oils that I found very interesting. Some of you might appreciate this.
The magazine tested penetrates for break-out torque on rusted nuts.
They are below, as forwarded by a professional machinist.
They arranged a subjective test of all the popular penetrates with the control being the torque required to remove the nut from a scientifically rusted environment.
Penetrating oil .......... Average load
None ........................... 516 pounds
WD-40 ..................... ... 238 pounds
PB Blaster .................... 214 pounds
Liquid Wrench ............... 127 pounds
Kano Kroil .................... 106 pounds
ATF*- Acetone mix...........53 pounds
The ATF-Acetone mix was a home brew mix of 50 - 50 automatic transmission fluid and acetone.
Note that home brew was better than any commercial product in this one particular test.
Our local machinist group mixed up a batch and we all now use it with equally good results.
Note also that Liquid Wrench is almost as good as Kroil for about 20% of the price.
Steve from Godwin-Singer says that ATF-Acetone mix is the best and you can also use ATF- lacquer thinner 50 - 50 mix.
*ATF = Automatic Transmission Fluid
US ARMY AIRBORNE INFANTRY
Old 03-11-2013, 05:09 PM
Hermes1 Hermes1 is offline
Vehicle: A Truck
Rep:2559
Interesting results, thanks for sharing. I have no scientific data to support it, just my observation, but I seem to have better results using PB Blaster over Liquid Wrench.
Old 03-12-2013, 02:21 AM
crabjoe crabjoe is offline
Vehicle: 2014 Ram 3500
Color: Maximum Steel Matallic
Rep:62
crabjoe will become famous soon enough
I've had exactly the opposite experience. I use to use Kroil. Had trouble finding it, so switched to PB Blaster... I felt it never worked, so I gave the Liquid Wrench Penetrating oil a try ... This is not the Liquid Wrench oil, in that metal tin, I had used over the years, it came in a spray bottle ... It worked like I was using Kroil, and it was cheapest penetrating oil on the shelf!
Old 03-12-2013, 10:28 AM
Vehicle: A Truck
Rep:2559
Well I guess that explains it, as I used the Liquid Wrench in the tin can. I found with PB Blaster it works best on potentially heavily corroded bolts etc. to spray it on a couple times a day over 2 or 3 days prior to really soak in. Is that the case with Liquid Wrench in the spray bottle also, or does it work within a few minutes of application?
Old 03-12-2013, 03:14 PM
Coastline's Avatar
Coastline Coastline is offline
Vehicle: 2013 Ram 1500 4X4
Trim Level: Laramie Longhorn
Rep:15
Coastline is on a distinguished road
I mixed up a bottle of this morning. Sprayed it on a bolt with a nut on it before I went to lunch, came back and the nut was laying on the floor
Old 03-12-2013, 04:18 PM
Vehicle: A Truck
Rep:2559
Good to know, I'll have to try it.
Old 03-12-2013, 08:10 PM
viperr817's Avatar
viperr817 viperr817 is offline
Vehicle: 2012 ram
Rep:195
viperr817 has a spectacular aura aboutviperr817 has a spectacular aura about
I use an industrial product called loosen-it. So far it outperforms kroil.
Old 03-12-2013, 08:40 PM
gopackgo69's Avatar
gopackgo69 gopackgo69 is offline
Vehicle: 2014 Ram 1500
Rep:20
gopackgo69 is on a distinguished road
Astro Glide works in some situations. You know...for deep penetration.
Just had to go there.
2014 4x4 Hemi sport , 3.92, Pro-comp level 2.75", Rear Fox 2.0, 1.5" springs, Diablo 93 Tuned. Toyo AT2 295/65/20
Old 03-12-2013, 08:47 PM
RansRAM's Avatar
RansRAM RansRAM is offline
Addicted to the Z
Color: PX8 Black
Engine: 2014-20?? 182ci (3.0L) L630DOHC V6 240hp 420lb/ft Eco-Diesel
Rep:2471
Interesting thread, thanks for posting.
sales@revelperformance.com
Old 03-13-2013, 02:09 PM
Rep:62
Nothing is instant.. With penetrating oils, you have to give them time to soak into the rust.
BTW, the last time, a few months ago, I used Liquid Wrench Penetrating (LW) oil was on rotors on a 2001 Expedition.. I let the rotors soak for about 6 hours and when I got them off, I could see that the LW had made it's way into all the rust.. For some, 6 hrs might seem a long time, but I originally started with PB blaster, on one side. I let it soak over night, and the rotor didn't budge. I went to pick up some sawzall blades, when I saw the Liquid Wrench ... No Kroil was there ... I figured why not give it a try. Still picked up the blades, figuring I'd need to cut. Well, low and behold, the LW worked. I sprayed both sides with it and let them soak.. Went back 6 hours later and both side came right off with one smack of the BFH. As long as I can find LW, I will never buy PB Blaster again!
