Old 03-13-2013, 10:02 AM
rsg1963's Avatar
rsg1963 rsg1963 is offline
Vehicle: 2006 RAM 3500; 2010 RAM 1500
Color: Black 2 tone grey
Rep:48
rsg1963 is on a distinguished road
Default 1500 transmission oil/filters for the first time.
It was a PITA. My 2006 has the resusable gasket but these 2010 1500's do not. You have to use RTV. (I personally use "The Right Stuff")
Brilliant. Not so much the issue of applying the RTV, but removing the old stuff was the pain. About an hour just to clean the pan. No way a service department is going to clean it like that before reinstallation. Unless they are using a air tool with wire wheel or something.
Besides the gasket, no issues at all. Kind cool about them having two filters. And it took more fluid than I figured to refill. (about 7 quarts). Luckily I bought the 2 1/2 gallon Amsoil jug so it was not an issue.
I checked Amsoil's capacity chart and sure enough it shows 6.6 quarts for the 4x4 tranny. http://www.amsoil.com/mygarage/vehic...rl2=2010+DODGE TRUCKS+RAM 1500 PICKUP+T
I guess I'm used to closer to 5 quarts for a filter change.
Really tempted to get the Mag Hitec transmission pan after this ordeal. Anyone have that here? Do they supply a reusable gasket or even a gasket at all?
RAM Pickup: 2010 1500 Laramie Hemi: Magtec Rear Diff cover/AmsOil 75w-110 Syn, 24" Magnaflow, Resonator delete, Line-X; Bilstein shocks with leveling kit 2.75";305/60-20 GY Wrangler Silent Armor Pro Grades; Lift Air Bag Suspension;
RAM Truck: 2006 3500 ST Cummins:Line-X; Leveling Kit 2" with Edelbrock shocks; Ultra Custom rims w/ 265/70-17 Goodyear Silent Armor Pro Grade; Backup Camera/NAV/DVD video/Reese 24K 5th wheel hitch; RDS 51 Gal tank/toolbox; Banks:CAI, MonsterRam 3.5",Monster Exhaust;Pac Brake Prxb.
Old 03-13-2013, 10:34 AM
Rep:1890
We most certainly do use wire wheels or Roloc discs on die grinders. We'd lose our collective asses if we tried to do them by hand.
Old 03-13-2013, 04:00 PM
rsg1963's Avatar
Rep:48
Thanks RamTech I kinda figured as much. It wasn't until 50 minutes into the scrapping and steel wooling that it dawned on me to do the same. Sigh... Live and learn.
Old 03-14-2013, 10:47 AM
Hermes1 Hermes1 is offline
Vehicle: 2015 Big Horn 3500 Cummins TD
Rep:2559
I see the point being made about the amount of time and effort involved in removing the old gasket material by scraping, especially when labor rates are involved. However, I was under the understanding that when mating surfaces are involved, such as a tranny pan or differential, using the more aggressive methods mentioned here would lead to fluid leaks because of marring the mating surfaces. I am interested to know more about this, and what Roloc discs are. Thanks.
Old 03-14-2013, 03:50 PM
rsg1963's Avatar
Rep:48
Hermes1 the Roloc term is referring to the system that attaches any number of pads/discs to a drill or air tool. In this case Ramtech was probably referring to a Roloc with a 3M conditioning disc of some grade or another. They will pretty quickly remove paint, goo, rust without digging into the metal surfaces. Kind of perfect for the issue I had actually. An actual wire wheel (if stiff enough) might scratch the surface.
Old 03-14-2013, 03:54 PM
Rep:2559
Cool thank you, learned something new.
Old 03-14-2013, 04:36 PM
westxsrt10's Avatar
westxsrt10 westxsrt10 is offline
Vehicle: 2010 Ram 1500 4x4 Hemi
Trim Level: Cool Chrome
Color: Cool Vanilla
Rep:79
westxsrt10 will become famous soon enough
The transmission filter Kit I buy has the gasket included + the 2 filters. I don't like the RTV route.
http://www.autopartswarehouse.com/se...ore=0.11575025
I've heard the Mag-Hytec trans. pan does little for lowering temps. Their Diff. cover are a must for the 1500's (just tight)
2010 Ram CC 1500 Hemi 4x4, 3.92 Mag-Hytec diff. cover
2008 Viper coupe, Belanger ceramic headers
2008 Ford F-250 CC,4x4,V-10
