Old 03-13-2013, 04:07 PM
itsmesukkka itsmesukkka is offline
Vehicle: 2012 Dodge Ram1500
itsmesukkka is on a distinguished road
Default Options for leveling or lifting an 2WD - PLEASE HELP
I have a 2012 ram 1500 2WD, What are my options for both leveling the truck or lifting it????
Old 03-13-2013, 09:50 PM
GrandpaSnugglz GrandpaSnugglz is offline
Vehicle: 2012 Ram 1500
Rep:14
GrandpaSnugglz is on a distinguished road
I have a 2012 2wd as well. I have a 2.5" daystar leveling kit on her and love it.
Old 03-13-2013, 09:53 PM
05cr125r's Avatar
05cr125r 05cr125r is offline
Vehicle: 2012 Big Horn QC
Trim Level: Big Horn 4x4
Rep:94
level looks good there gramps
Mods; Line X, Bilsteins set at 2.1, Magnaflow 18", Debadged , Cool White LED Interior, LED license plate, Cool White LED reverse, Fronts tinted 20 %, Stubby Antenna,AVS WindowVisors, Black Honeycomb Grille Insert, Green Performance Air Filter, SuperChips Flashpaq 3482
Old 03-13-2013, 09:57 PM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
do you want to spend $80-200 or $1000-16000 roughly? that's the difference between leveling and lifting. I suggest hellbent steel leveling kit for your 2wd. or u do a body lift, or more expensive a suspension lift. the latter2 require $600-800 roughly in labor to install by a shop. (from my research).
Old 03-13-2013, 11:25 PM
Love how it looks, how long have you had the leveling kit on? Any problems with it so far?
Also whats the biggest tire size you can go with the 2.5" level.
Old 03-13-2013, 11:30 PM
Right now im not sure exactly what I wanna do, I just want to get several options because the more I look for leveling kits and suspension lifts I realize there is barely anyone that makes them for the 2WD, Hellbent steel only makes them for the 4WD model, and I think ive seen maybe one suspension lift for the 2WD's, thats why I started this thread to find out who makes stuff for the 2WD's and also see if anyone has these products and there experience with them.
Old 03-14-2013, 07:41 AM
Rep:1900
http://cstsuspension.com/products/sf...ID2/8/sfID3/66
crap I just realized those years only go up to 2011...maybe they still work the 2012? I don't see why not
Old 03-14-2013, 10:04 AM
Rep:14
Thank you. I've had the level since the beginning of the year. No problems at all, knock on wood. Rides and drives same as stock.
I have 275/65/20 on now, which I think is equivalent to a 34x11 if I'm not mistakin. I have a bit of room left to go bigger, no rubbing anywhere and good clearance off the UCA on a -12 offset wheel. I would like to try to get a 35x12.5 later down the road. If anything ill throw on a 1" body to make it happen.
Old 03-14-2013, 11:44 AM
I also wanted to know if it still had a little rake in the front or was it completely level once you installed the spacers?
Also I went on daystars website and I only see the 1.5" spacers, I dont see the 2.5".
Old 03-14-2013, 11:48 AM
Do you of anyone with this kit so I can see come pics and get there feedback on the quality or their experience with the product.
