Cruise comes on then turns off. - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Electrical
Old 03-13-2013, 08:33 PM
IndyGreg IndyGreg is offline
Vehicle: 2002 Dodge Ram SLT Quad 2wd
IndyGreg is on a distinguished road
Default Cruise comes on then turns off.
Brand new to me truck. When I first push cruise button it will light for a second or 2 then go out. i can do it again and it comes on but goes out even faster for 2 or 3 times then won't light up at all.
It will not stay on long enough for me to set cruise and sheck if it works. I believe the problem is in the switch on steering wheel. is there a way to verify this or possible take apart and clean contact?
Thanks for your feedback.
Old 03-17-2013, 08:50 PM
Default Still not working
So if I start motor and put foot on brake cruise light will stay on for 30 seconds plus, as soon as I release brake within a second or two cruise light goes off.
So I thought it must be the brake light switch and it is a cheap enough part.
replaced it with the same results.
If it were the wheel speed sensors would it not stay lit while sitting still? could it be the PCM?
Old 03-19-2013, 07:27 AM
tjbiker031's Avatar
Trim Level: SLT - Quad Cab
Color: Graphite Metalic
Rep:118
Are you sure the switch is adjusted properly? I had that same issue on my 97 Mitsubishi Eclipse GST a few years back. I would suggest before you start fearing the worst, get a copy of the Dodge Ram service manual online (you can easily get one for free) and start troubleshooting with that. It will save you a bunch of time than scouring the internets looking and waiting for information and feedback.
Old 03-19-2013, 08:25 AM
tjbiker031's Avatar
Rep:118
Ok taking a look at ShopKey at school because this issue keeps nagging at me.
It says under troubleshooting to
1. Ensure no DTC (codes) are in the system.
2. Re-adjust brake switch
3. Test servo (cruise system under hood)
4. check vacuume leaks
5. check linkage for throttle and cruise.
6. Check wireing connectors
then it goes on in depth more about defective PCM and a bad servo.
Old 03-21-2013, 10:17 PM
Franklg42 Franklg42 is offline
Vehicle: 2008 Dodge Ram Big Horn
Franklg42 is on a distinguished road
Default Wheel sensor?
I replaced my drivers side wheel bearing about a week ago and my truck is doing the same thing. The connector didn't match up correctly, however the pins were right so i reformed the connector to make it fit. I wonder if I have the wrong part.
Old 03-22-2013, 07:38 AM
tjbiker031's Avatar
Rep:118
More than likely. The issue when the connectors dont fit is that the wireing could be wrong and not allow certain componets to work and in some cases (generically) can fry electrical componets.
Old 03-27-2013, 08:59 PM
Default Checking for codes this weekend.
I should finally have time to check for codes this weekend. As for #2 When I installed new brake switch it says they can only be adjusted once.
What I confuses me is why holding brake pedal down allows the cruise control light to stay on? I could see a false signal being sent and turning off cruise when it thinks I have applied the brake. Even when working right the dash light should stay lit.
Old 03-27-2013, 09:01 PM
So your light is turning itself back off? Have you tried to press brake pedal and see if it will stay lit? If so maybe it could be a wheel speed sensor?
