Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > 4.7L PowerTech V8 Specific Topics
Old 03-13-2013, 10:01 PM
Sabyre Sabyre is offline
Vehicle: 2002 RAM 1500 Quad Cab Sport
Color: RED
Sabyre is on a distinguished road
Default Stalled Today Wouldn't Restart
2002 4.7 1500, 214k Miles
Not sure what to look for on this. The truck normally would stall out after a few minutes with a loping idle. You could feather it to keep it going. I was thinking it was a sensor Cam, IAC, something like that. Seemed like it (the truck) wasn't sure how to idle. You could always just restart it.
Today however, It stalled while under thottle (gas pedal depressed) going down the road. And would not restart. It would simple turn over and over and over... Nor aparent firing. 10 or so minutes after trying to restart it the battery went dead.
We had it towed (Thank god for AAA) and are awaiting it to be delivered (140 Mile Tow).
What should we look for. What would cause the truck to stall and not restart when it normally would restart with no problems?
"We are the music makers and we are the dreamers of the dreams" - Willy Wonka
Old 03-14-2013, 09:30 AM
Resident Technician
Rep:1909
Start with the obvious. Check fuel pressure and flow volume, check for fire at the plugs and check the PCM for any codes.
Old 03-14-2013, 11:17 AM
Color: RED
I pulled the code p0108 manifold absolute pressure/BARO sensor high input.
I got the truck running and it starts right up, has a loping idle though and eventually will stall out, but it starts right back up.
If I give it throttle up to 3-4k RPM it stumbles and pops like its not firing right.
Not sure how I can check the fuel pressure.
Also, while the truck is running, the engine light stays on, as well as the ebrake light, and the abs light flashes off and on.
Old 03-14-2013, 11:22 AM
Resident Technician
Rep:1909
The P0108 is the first thing to go after. You have either a wiring problem or a faulty PCM or MAP sensor. You'll need a scan tool and DVOM to diagnose the problem.
Old 03-14-2013, 11:24 AM
Color: RED
I have both, where do I start?
Old 03-14-2013, 11:28 AM
Resident Technician
Rep:1909
The attached file is the procedure for a P0108 diagnostic.
File Type: pdf 7_2_2 P-0108 MAP SENSOR VOLTAGE TOO HIGH.pdf (176.6 KB, 4 views)
Old 03-14-2013, 11:32 AM
Color: RED
Thank you very much, going out to do that now.
Old 03-14-2013, 04:29 PM
Color: RED
I replaced the MAP sensor and cleared the code. The old sensor was cracked and messed up. It ran great for about 5 minutes. No more idle surging. I thought we had it fixed then it died.
Started it again and got some poping, backfires, and rich exhaust.
Got codes p0320 ignition distributor engine speed, and p1391 intermittent loss of cmp or ckp.
We also replaced the battery.
I feel like we are getting to the point where we are going to keep throwing sensors at it and hoping for the best.
A couple of times when it stalled out the fuel pump stayed running and the tach would bounce all over the place... 3k, 7k, 5k....
Old 03-14-2013, 04:35 PM
Resident Technician
Rep:1909
So the P0108 didn't return but the P0320 and P1391 appeared? Have you done a voltage drop test across the ground side between the battery negative and engine?
Old 03-14-2013, 04:37 PM
Color: RED
That is correct... P0108 didnt return, but the others appeared.
Voltage drop test?
