Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > 4.7L PowerTech V8 Specific Topics
ZDOG
Old 03-18-2013, 11:02 AM
Resident Technician
Rep:1911
And here's the factory diagram for 2002. This applies to both early and late DR builds.
Old 03-19-2013, 03:24 PM
Sabyre Sabyre is offline
Vehicle: 2002 RAM 1500 Quad Cab Sport
Color: RED
Sabyre is on a distinguished road
Switched out the IPM and all is well. What a nightmare that was.
"We are the music makers and we are the dreamers of the dreams" - Willy Wonka
Old 03-19-2013, 03:25 PM
Resident Technician
Rep:1911
Did that cure all the problems?
Old 03-19-2013, 03:28 PM
Color: RED
Yeah, the gauges no longer freak out, it no longer stalls, and at tempereture fuel system primes as normal.
The only issue now with the truck is the abs light, speedometer not working, heater blower only blows on high. Ill should make a new post for that I think.
Old 03-19-2013, 03:35 PM
Resident Technician
Rep:1911
Heater blowing on high can be attributed to the blower motor resistor going bad. Simple, inexpensive fix. Make sure the plug isn't melted as well. As for the ABS, start by scanning the module.
Old 03-19-2013, 09:24 PM
Color: RED
Replaced the speed reference sensor on the rear end. Same issue, ABS flashes and dings every couple of seconds.... No code thrown.
I checked the connector on the ABS module (While I was working the other issue) and it seemed fine, all the wires seem in good shape.
ABS module bad? There a way to test it?
Old 03-20-2013, 08:50 AM
Resident Technician
Rep:1911
Were there no codes stored in the ABS module? If not, I would recommend checking the power and grounds going to it as a first step.
Old 03-20-2013, 08:55 AM
Color: RED
I don't have a scanner for the ABS. Is there another way to pull codes from it?
Old 03-20-2013, 09:07 AM
Resident Technician
Rep:1911
An ABS capable scan tool is the only way I'm aware of.
Old 03-20-2013, 08:24 PM
Color: RED
Had the dealership scan for codes. Came up with Codes:
1. 82 - Number of tone ring teeth out of range.
2. 63 - Rear reset switch closed.
Oddly he said he hadn't seen those before. The truck has larger tires than stock, could those be the cause?
