Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > 4.7L PowerTech V8 Specific Topics
Old 03-21-2013, 09:08 AM
Resident Technician
Rep:1909
I've never seen them before, but judging by the diagnostic chart, you have a bad ABS hydraulic control unit (HCU). 63 is set by an internal fault with the HCU and 82 can be caused by the 63, or by the incorrect axle being programed into the HCU.
Old 03-21-2013, 09:12 AM
Sabyre Sabyre is offline
Vehicle: 2002 RAM 1500 Quad Cab Sport
Color: RED
Sabyre is on a distinguished road
I believe the axe was swapped out by the PO. Was the 3.55 standard stock rear end for these?
"We are the music makers and we are the dreamers of the dreams" - Willy Wonka
Old 03-21-2013, 09:31 AM
Resident Technician
Rep:1909
I believe it was but axle ratio is irrelevant to this code because the number of teeth on the tone wheel will remain the same. If the PO installed something like a 10-1/2 and didnt reprogram the ABS accordingly, then you'd get this code.
Old 03-24-2013, 10:40 PM
Color: RED
The PO replaced the PCM. Would the PCM vin vs. the ABS CPU not matching cause this?
Old 03-26-2013, 04:41 PM
Color: RED
Anyone? Any ideas about the VIN not matching ABS vs PCM?
