Old 03-14-2013, 12:50 AM
superjuggie's Avatar
superjuggie superjuggie is offline
Vehicle: 2010 Dodge Ram 1500 5.7L
Trim Level: Sport 4x4
Color: Metallic Black
superjuggie is on a distinguished road
Default Those of you With Under Rear Seat Mounted Subs Step in
how are you guys finishing your setups underneath your boxes?
are you laying down dynomat or deadening mat before putting the box in.. are you bolting the boxes to the cab of the truck?
i ask because when i had two 10'' L5's under the rear seat the box rattled so hard from the bass that we had to go back and the installers added two layers of dynomat underneath the sub box. although that helped a lot.. during hard hitting songs the box still rattled a bit under the seats and it was so annoying, almost like i couldn't enjoy the bass at all
so are any of you bolting your boxes down or what do you suggest?
Old 03-14-2013, 02:17 AM
stef0703's Avatar
stef0703 stef0703 is offline
Vehicle: 2010 dodge ram 1500
Color: BLUE
stef0703 is on a distinguished road
I made my own fiberglass box, doesnt move and no rattling!!!!!! i hope you figure something out...
Old 03-14-2013, 08:18 AM
ssteadman09 ssteadman09 is offline
Vehicle: 2009 Dodge Ram
Trim Level: TRX-4
Color: Red/Tan
Rep:19
ssteadman09 is on a distinguished road
The box I have almost wedges itself under there. I have 1 12" under the driver rear seat. Put one layer of dynomat back there, Only thing that rattles is my a-pillar on the passenger side that I can hear.
Old 03-14-2013, 09:13 AM
autokraftgt autokraftgt is offline
Vehicle: 2011 2500
Trim Level: big horn
Color: grey
Rep:31
autokraftgt is on a distinguished road
I sound deadened the inside of the tubs extensively, but other than that No rattles and no I did not bolt the box to the truck. Like mentioned up top...it's wedged in there pretty good. Having 40lbs of subwoofer helps too
Old 03-14-2013, 10:51 AM
I'll try sound mat first with my new setup and report back to you guys with my new setup
Do you line the entire tubs with sound mat?
Old 03-14-2013, 04:58 PM
Maddevill Maddevill is offline
Vehicle: 2003 Dodge Ram 1500 Quad
Color: Grey
Rep:27
Maddevill is on a distinguished road
I have a single 10" under the rear passenger seat in a Thunderform box. Tight fit, the only things that rattle are my door mirrors.
Old 03-14-2013, 09:36 PM
I push the skinny pedal
Rep:3298
I would definitely do a layer of vibration dampning material, but I would also add a disconnect layer of closed cell foam to absorb unwanted noise as well.
Kurtis
Old 03-15-2013, 07:43 AM
Vehicle: 2011 2500
Color: grey
Rep:31
I did 4 layers in the tubs...they resonated something awful!
Old 03-16-2013, 01:33 PM
StoneyWV StoneyWV is offline
Vehicle: 2010 Ram Quad Cab 4X4
Rep:27
StoneyWV is on a distinguished road
If you are doing fiberglass yourself, or buying a custom laid fiberglass you don't need to take up space with deadening material down there. The fiberglass will not resonate if it's done proper. The companies that are manufacturing fiberglass boxes have them designed to fit against the bare metal, you could run into issues if you put anything in there. If your going with a plastic box, then I would use something.
2010 QC ST, 5.7L, 4.10 Gear Swap, 5100 Leveling Shocks at 1.7", K&N Drop-in, Pioneer U310BT, 12" Dayton/Net Audio Sub, JL Components, ARC Audio Amps, Magnaflow 14 inch, Granite Alloys sporting 34" BFG T/A KO, HID conversion full blackout.
Old 03-17-2013, 12:52 AM
ImAHemi ImAHemi is offline
Vehicle: 09 Ram QC
Color: Deep water blue pearl
Rep:24
ImAHemi is on a distinguished road
I deadened and bolted the enclosure down.
