Old 03-14-2013, 11:31 AM
Bigwrench Bigwrench is offline
Vehicle: 2012 ram
Trim Level: sport
Color: true blue
Bigwrench is on a distinguished road
Default Lowering a 2012 Ram Sport 4X4
Hi all
I am lowering my new Ram sport crew cab, 4x4...
Thinking about a kit from Ground Force -9984..
Anyone have input, good, bad, ....
Thanks in advance
Old 03-14-2013, 12:53 PM
Kcbigbadram's Avatar
Vehicle: 2014 1500
Trim Level: limited
Rep:497
Have the same kit on mine. Had it about 6 months, so far no complaints it rides just a bit rougher since I have 22's on there now, but well worth it for the look
Old 03-14-2013, 07:14 PM
Vehicle: 2012 ram
Trim Level: sport
Color: true blue
Nice truck ...Thats the look i am after thanks..
Old 03-14-2013, 09:30 PM
CdnoilRAM CdnoilRAM is online now
I push the skinny pedal
Rep:3277
The gf kit works, but the McGaughy's 2wd kit will also work. I will be installing my McG's kit in a few weeks.
Kurtis
Old 03-14-2013, 09:45 PM
Vehicle: 2012 ram
Trim Level: sport
Color: true blue
Save your money unless your truck is a 2wd...I purchased this kit ( McGaughys ) for my truck, the front springs are different, 2wd springs are larger in diameter. They will not fit into the the coil over struts...
Old 03-14-2013, 10:02 PM
Rep:3277
Ah, good to know about the springs; I went with the spindles, I know they're the same.
Kurtis
Old 03-15-2013, 12:42 AM
5280RAM's Avatar
5280RAM 5280RAM is offline
Vehicle: 2012 Dodge Ram 1500 4x4
Trim Level: SLT Big Horn
Color: Mineral Gray
Rep:43
5280RAM is on a distinguished road
How low will this kit get you? The GF kit is 2/3 right?
Old 03-15-2013, 08:08 AM
Vehicle: 2012 ram
Trim Level: sport
Color: true blue
What is the part number for the kit with spindles..I like the spindle option better than just springs..Was told the 2wd spindles where different, and there wasn`t anyone offering lowering spindles for a 4wd...Thanks for the input guys...
Old 03-15-2013, 09:20 AM
Rep:3277
I have been told there is no difference in the spindles between the 2wd and the 4wd except the location of the axle hole and steering arm lug, which needs to be relocated if you're dropping a 4wd with spindles anyway. I'm going to give this a try and see how it goes and I can let you know the results. If the weather's good next week I'll be doing the swap.
The McG's deluxe kit number is 44050 our you can get just the spindles 44001.
Kurtis
Old 03-15-2013, 10:39 PM
Vehicle: 2012 ram
Trim Level: sport
Color: true blue
Thanks and please let us now how you made out.....you might save me some head aches..
