Bleeding Brakes Problem - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 03-14-2013, 06:51 PM
TankGod78's Avatar
TankGod78 TankGod78 is offline
Vehicle: 2004 Dodge Ram 1500
Color: Blue
Rep:152
TankGod78 has a spectacular aura aboutTankGod78 has a spectacular aura about
Send a message via MSN to TankGod78
Default Bleeding Brakes Problem
So here is what I have redone/replaced on my truck in the last month. (2004 Dodge Ram 1500 / Quad Cab / 4.7 / 4X2 / 6 ft. bed) Both side tie rod ends, both side rotors, both side hub assmebly, both side brake pads, both side calipers, and the rack an pinion. Next to follow is an alignment.
This is problem now. I did the calipers on both sides very last. After putting the new brake pads in the new calipers I rehooked the brake lines and pumped the brakes til it was a steady stream of fluid came out of the bleeder valve. After driving the truck, it now takes 3 to 4 pumps to get the brakes to start working normally (while driving). Yeah, I know right... and this is not just a one time thing. It does it every single time I push the brakes.
Please help! Any ideas on what to do to fix it? Just so everyone knows, I am really trying to do all the work on my truck myself so taking it to a shop will be a last resort. Thanks to all who can help.
"Marines never reteat, we just fight in a different direction"
Old 03-14-2013, 07:09 PM
brandonjansen's Avatar
Moderator
Trim Level: Laramie Limited
Rep:2140
Sounds to me like you still have an air pocket somewhere in the brake system. I'd try re-bleeding them all again. Remember, start with the one furthest away from the master cylinder and move to the closest.
Also, regarding your technique of bleeding (how you described it is a little unclear)... Did you just open the bleed screws and then pump the brakes until a steady stream of fluid came out? Because if so, that's not right... You need to have someone inside the truck pump them up a few times to build up pressure, open the bleed screw to let the pressure out, close the bleed screw, and then have the person inside release their foot off the brake.
I've also seen people install the calipers on the wrong side with the bleed screw at the bottom.... air rises, they need to be at the top.
Old 03-14-2013, 07:29 PM
TankGod78's Avatar
Color: Blue
Rep:152
Oh wow, really, lol??? Yes I did everything you said that was "INCORRECT". I just pumped the brakes til a steady stream of fluid came out and put my calipers on the wrong side. I put the bleeder valve on bottom. Ok well I am going in my garage and getting to work, lol. Thanks so much. I will update you when completed.
Old 03-14-2013, 09:26 PM
Rep:2929
Another thing, if you have ABS braking system, you also need to bleed that system
Old 03-14-2013, 10:57 PM
Moderator
Rep:2140
Also make sure you're filling up the master cylinder as you go. If you let it get empty you'll have to start over.
Old 03-15-2013, 02:46 PM
HemiLonestar's Avatar
Rep:300
HemiLonestar is a jewel in the roughHemiLonestar is a jewel in the roughHemiLonestar is a jewel in the roughHemiLonestar is a jewel in the rough
You will need access to a DRBIII or have to take it to a dealer to bleed the ABS pump.
"Big Red"
2003 Ram 1500 QC Hemi Lonestar "Big Red"
2006 Charger R/T "Little Red", 2005 Magnum R/T
(Mods list in profile)
Old 03-15-2013, 11:32 PM
TankGod78's Avatar
Color: Blue
Rep:152
Well the I have rear ABS not front and I did not let the master cylinder go empty. I had my son help to make sure of that. So what you said in the very begining Brandon Jansen worked perfectly. I switched the calipers sides so that the bleeder valve was on top because air rises, lol. Then bleed the side furthest away from the booster first, then had my son pump the brakes til it was hard to press, had him hold it down then closed the bleeder valve, then let off the brakes, then did the other side the same way. I di all that in 45 mins to include taking off the front tires and putting them back on
Took it for test drive and I could tell right away that it worked. Thanks you so much for your help.
And I dont even know what a DRBIII is HemiLonestar, lol.
Old 03-15-2013, 11:35 PM
TankGod78's Avatar
Color: Blue
Rep:152
BTW, GTyankee I use to live in San Diego County as well. Palm City (off palm ave). About 10 north of TJ, lol. I use to work at the NASSCO shipyard right across from the NAVY base. Thanks for all you help
Old 03-16-2013, 02:17 AM
Rep:2929
I deliver or i should say Escort Oversize Loads to NASSCO quite often
General Dynamics moved to Mexicali Mexico & they make the ships parts down there now & they have to be transported to NASSCO near 28th street
Old 03-16-2013, 02:22 AM
Moderator
Rep:2140
Glad you got it all working again. Let me know if you ever have questions about other maintenance things. I'll try to help you out to the best of my ability.
