tonneaucovered.com
Old 03-14-2013, 08:51 PM
Canadian Hemi Pride's Avatar
Vehicle: 2008 Dodge Ram 1500
Trim Level: SXT 4x4
Color: Silver/ Black
Rep:2826
Default How to clean a throttle body?
Alright so since I had seen a picture of someone posted the pic of their old throttle body and the grime build-up.. I figured it was time to get mine off and clean it.
What should I use to clean it with, and should I take it off the truck or just leave it on?
IG:@briley59
Old 03-14-2013, 09:00 PM
S.C. Express S.C. Express is offline
Vehicle: 2012 Ram Express
Rep:63
S.C. Express will become famous soon enough
I read somewhere on here that a Dodge tech said to use Mopar brake cleaner. Anything that can cut oil but not eat aluminum should work. DEFINITELY take it off!!
Jones MaxFlow 18" muffler swap, Green Performance drop in air filter..
Old 03-14-2013, 09:06 PM
brandonjansen's Avatar
Trim Level: Laramie Limited
Rep:2095
+1. Take it off for sure. If it's really bad scrubbing it with an old toothbrush or scotchbright works well too.
Old 03-14-2013, 09:12 PM
Hemiman345's Avatar
Hemiman345 Hemiman345 is offline
Vehicle: 2010 1500 4x4
Color: Inferno Red
Hemiman345 is on a distinguished road
On my 04 I cleaned my event every other oil change. Take it off and I used a shop rag and starter fluid/ carb cleaner. I also remove the pvc valve and cleaned it at the same time
Old 03-14-2013, 09:17 PM
I push the skinny pedal
Rep:3308
Remove it, then you can get into the intake manifold as well. I cleaned mine with seafoam spray, but the other suggestions will work, though I'd be careful with carb cleaner around anything with electronics since most will corrode copper bearing alloys. I soaked it for a good hour, then went at it with a scotchbrite pad and some detailing brushes until it was clean. While I worked the TB I also soaked down the inside of the intake manifold and then cleaned everything I could reach with rags.
Kurtis
Old 03-14-2013, 09:19 PM
Trim Level: SXT 4x4
Rep:2826
Alright perfect. Thanks alot guys.. think this may be tomorrows job depending on the weather.
IG:@briley59
Old 03-14-2013, 09:21 PM
BlueJet BlueJet is offline
Vehicle: Blue
Rep:3934
http://www.ramforumz.com/showthread.php?t=46454
Old 03-14-2013, 10:03 PM
byeex001's Avatar
byeex001 byeex001 is offline
Vehicle: 2007 Dodge Ram 1500
byeex001 is on a distinguished road
Yea... My throttle body WAS pretty disgusting, wasn't it..? Haha
K&N CAI, 18" Magnaflow, SuperChips Flashpaq, 87mm TB, Line-X Bed Liner
Old 03-14-2013, 11:36 PM
Trim Level: SXT 4x4
Rep:2826
Lmao Yea it was.. It just seems like one of those little things that slips by.. And my old owner never actually worked on the truck. So I am gonna assume I am in for a treat. But whatever.. I love my Ram and want to make it the best I can... I will clean every inch of that engine with a tooth brush if needed.
IG:@briley59
Old 03-17-2013, 11:00 PM
Ramguy65's Avatar
Ramguy65 Ramguy65 is offline
Vehicle: 2014 Dodge Ram Sport
Rep:50
Ramguy65 will become famous soon enough
Had my truck in the shop because it was running a little rough. Had my whole fuel system cleaned. Mechanic said my throttle body was very dirty. Truck runs really good now! This is something I will be checking regularly going forward. Doesn't seem to be that hard to do. I am sure I would have noticed when I put my intake in. Looked at it when I had my intake tube off this weekend...looks nice and clean still!
2014 Ram 1500 Sport QC
Hemi, 3.92, Mopar Side Steps, Hemi Mud Flaps, Bakflip F1 Tonneau Cover, BT Catch Can, Magnaflow True Dual Catback Exhaust
