Windshield Wipers acting funky. - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Electrical
Old 04-10-2013, 08:08 AM
robustRed's Avatar
robustRed robustRed is offline
Vehicle: 2008 Dodge Ram 1500
Trim Level: Lone Star PKG
robustRed is on a distinguished road
hey maveric, the TIPM is the control moduel for just about everything on the truck. everything on the body of the truck (lights,wipers, windows, seats, blinkers, ect.) is controled by this module. More than likely this is the problem. but you should still have the dealer check it out whit their scan tool (i think its called the DRB III) so they can confirm. I am going to take mine to the dealer some time in the next couple of weeks so they can do their thing. I am thinking that the cost out the door is going to be somewhere around $400 with the cost of labor and the part. I am going to have to bite the bullet but i will have working windshield wipers. and safety comes first.
2WD-Dsp 93 tune-55 series tires-3.92s-PacesetterLT Headers w/ 3in catted y-pipe- DynoMax Race Bullet- 2.2K ohm power wire- hellwig rear sway bar- 190 Degree Thermostat-
Old 04-10-2013, 05:32 PM
Basher Basher is offline
Vehicle: 2006 Dodge Ram MegaCab
Rep:49
Basher is on a distinguished road
I currently have this problem in my truck too. I have an 06 1500 MC. I have pulled the battery terminals and body ground, cleaned, wire brushed and put back together with dielectric grease, hoping it was a bad ground causing this. But nothing has worked. Recently I have had issues with the truck being dead in the morning. Enough juice to power everything but the starter. This used to happen after sitting for a week+, but it happened twice last weekend, and i have been driving it everyday.
Anyway, I don't know if these 2 problems are related, but it would be nice to fix them together!! I put a new wiper switch in when I bought the truck 2 years ago, and the wiper problem went away until recently...
I'll follow this post and see if anything becomes of it. Thanks for the insight to the recall and the module thing.
2006 MegaCab 2wd on 22's
1956 1/2ton Dodge: 318/904 3.23's: Chopped Dropped and Shaved
Old 04-10-2013, 11:36 PM
tjbiker031's Avatar
Vehicle: 2002 Dodge Ram
Trim Level: SLT - Quad Cab
Color: Graphite Metalic
Rep:118
Its time to get a new battery if it is hard to start or wont start. Test your alternator while your at it. Your average parts store should be able to help you out testing both.
Old 04-11-2013, 12:12 PM
Rep:49
Thanks tjbiker,
the battery is fine. it is only a year old and shows 12.7V on the meter. I cleaned the terminals and connections at the starter and it hasnt failed me since. crossing my fingers! Dash gauge shows that i am putting out enough charge, but its probably wise to put a meter on that as well
Bash
Old 05-09-2013, 06:06 PM
malsamd malsamd is offline
Vehicle: 2005 Dodge Ram 2500 Cummins
malsamd is on a distinguished road
When I bought my 05 2500, a year later this same thing happened to me with the wipers. Took it in under warranty and they had to replace the entire wiper assembly
Old 05-09-2013, 06:40 PM
JWM59's Avatar
JWM59 JWM59 is offline
Vehicle: 2013 Dodg Ram
Rep:148
JWM59 will become famous soon enoughJWM59 will become famous soon enough
My 05 did that and I also had to replace wiper assembly.
Old 06-28-2013, 04:39 PM
Danstona Danstona is offline
Vehicle: 2005 Dodge Ram 1500 4x4 5.7L
Trim Level: Hemi Sport
Rep:35
Danstona is on a distinguished road
My brothers wipers stopped working altogether too and his auto tech friend replaced the main wiper motor.. then had issues with the intermittent wipers not working properly.. he said he pulled the motor and cleaned contacts on it and the module and put it back in and everything was fine... brothers truck is a 2004 Sport... and my 05 Hemi Sport is doing the same thing with intermittent wipers sometimes won't work unless I switch them full on and then wait a few seconds to turn down.. but they just wipe steady.. not fast fast.. but steady.. the slow intermittent doesn't work.. been like this for almost 3 years... If its as simple as cleaning some contacts I am game.. I just need to know where to start. Anyone?
Old 06-29-2013, 07:55 PM
heath.robertson heath.robertson is offline
Vehicle: 04 Ram 1500 Quad Cab HEMI 5.7L
heath.robertson is on a distinguished road
I'd love a solid response on what is causing this, because I'm having a very similar problem.
Mine's an '04, and none of the wiper settings really work other than the second fastest. Sometimes I can back it back down from the second fastest, but it stays at the same speed until I switch it off. The fastest setting is also completely dead. Weird problem, and potentially dangerous if it were storming badly!
Old 07-01-2013, 09:59 AM
Rep:49
I cant really say that I fixed it, but I removed the main grounding strap from the battery to the body, cleaned and wire brushed it, then cleaned and wire brushed the batt terminal. Sprayed everything down with battery terminal protector and it all seems to be working a lot better.
Good luck!
Old 07-15-2013, 09:07 AM
Seacoast-NH Seacoast-NH is offline
Vehicle: 2005 RAM 1500 Orng Cnty Chpprs
Seacoast-NH is on a distinguished road
Guys - ever figure out where one can buy this or how much it costs?
-J
2005 RAM Orange County Choppers edtn Quad Cab.
