Old 03-16-2013, 10:20 AM
Bighorn5.7 Bighorn5.7 is offline
Vehicle: 2014 ram 1500
Trim Level: Express Blackout
Bighorn5.7 is on a distinguished road
Default leveling kit FYI
I did a fair amount of research before ordering my leveling kit for my 07 ram. I decide to install and figured in a few hours it would be done! I pulled apart drivers side and disassembled everything and was going great, then i hit the wall known as the lower strut mounting bolt! It is frozen in place and after an hour of frustration i reassembled and am rethinking install. So i decided to google this issue and there are post everywhere this is a common problem on all rams even newer ones. So i am sure with some work the bolts can be removed but just be ready for a fight more than likely if you are installing yourself! The nieghbor has a hoist and am hoping once up in the air a sledge hammer and some new bolts will do the trick??
Old 03-16-2013, 11:23 AM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
I used a big ass hammer then had to sawzall the bushings out. then replaced both bushings and bolts. http://www.ramforumz.com/showthread....ght=strut+bolt
Old 03-25-2013, 11:57 AM
UPDATE, I GOT THE NEIGHBOR TO HIT THE BOLTS WITH THE AIR HAMMER FROM BOTH SIDES A FEW TIMES AND IT PUSHED THE BOLTS RIGHT OUT. CLEANED THE BOLTS UP AND COVERED IN NEVER SIEZE AND REASSEMBLED. MY TRUCK IS GOING ON 6 YEARS OLD OF MINNESOTA WINTERS SO THIS SHOULD DO THE TRICK FOR MOST THAT ARE TRYING TO GET THEM OUT?? GOOD LUCK!
Old 03-25-2013, 12:30 PM
Rep:1900
glad you got it out without having to replace the whole bushing. Good job!
I dont even live in a harsh winter state and mine were SO BAD.
