Spring Brake Service - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Dodge Ram Detailing and General Maintenance Forum > Brakes
Brakes Brake Maintenance and Replacement
Old 03-16-2013, 01:12 PM
RansRAM's Avatar
RansRAM RansRAM is offline
Addicted to the Z
Color: PXR Black
Rep:2477
Smile Spring Brake Service
Completed my annual brake service this morning. Did the front only for now. Removed calliper, lubricated the pins, checked the pads and re-painted them. Pics are the proof.
sales@revelperformance.com
Old 03-18-2013, 11:13 PM
toolfreak101 toolfreak101 is offline
Vehicle: 2005 dodge ram
Color: silver
toolfreak101 is on a distinguished road
is there a special paint for calipers and where would i buy it.
p.s.your calipers look good
Old 03-19-2013, 08:03 PM
RansRAM's Avatar
Addicted to the Z
Color: PXR Black
Rep:2477
Thanks, I replied in your other thread. The paint I used comes as a kit from UAP Napa. Its the only place I could find caliper paint that can be brushed on. As you can see I removed my calipers to paint them properly. Only thing is that I should of sanded them down a bit better on the one side. Oh well I end up touching them up every spring anyway so next time will be better.
Old 11-15-2013, 12:19 PM
RC51 RC51 is offline
Vehicle: 2016 Laramie Limited
Trim Level: Laramie Limited edit
Rep:58
RC51 will become famous soon enough
Im use to servicing my calipers on my vehicles. Is there anything different on Ram's than the Honda/Acura cars and trucks I have normally done?
Old 11-15-2013, 04:49 PM
RansRAM's Avatar
Addicted to the Z
Color: PXR Black
Rep:2477
No they are pretty old school concerning the mounting hardware. The sliders are the one thing that tends to seize up if you neglect them. This will cause uneven pad wear and sometimes a significant pull to the left or right while braking.
Old 11-15-2013, 09:23 PM
Rep:58
Thanks for the information. So far through my research it looks like the stuff I do myself like brake servicing, pads,tire changeover should be straight forward.
Old 11-15-2013, 09:33 PM
RansRAM's Avatar
Addicted to the Z
Color: PXR Black
Rep:2477
Yes sir, pretty straight forward. I tend to do as much as I can on my own as well and just keep the receipts and take pictures. The only things that really concern me somewhat are the electronics, sensors and on board computer modules. They are pretty hard to service on your own and are expensive to replace. So far I've had no issues with them, my truck has performed flawlessly. I have done all my own oil changes, replaced the fluid in the front and rear diffs, performed standard brake service, installed billstien levelling struts and rear shocks, and performed tire rotation semi-annually.
Old 11-15-2013, 09:59 PM
Rep:58
I dont do most of the work you described. I was considering doing the oil changes myself when the dealer told me how much to do a synthetic oil change. I think like over $130. Costco however has it around $65 so for me it beats getting under vehicle and draining 7 litres of oil and putting on a oil filter. My other concerns on electronics etc. is something that concerns me as I ordered a fully optioned Laramie with a ton of electronics. I'm coming from a extremely reliable Ridgeline (had two of them).
