spark plugs - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8
Old 03-17-2013, 02:15 PM
toolfreak101 toolfreak101 is offline
Vehicle: 2005 dodge ram
Color: silver
toolfreak101 is on a distinguished road
Default spark plugs
i changed my plugs on my truck last week and now the revs will not go above 1k after i switch on truck.4.7l v8 .just wanted to know what everyone thinks could be the problem
Old 03-18-2013, 01:04 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
What plugs did you use? It's best to replace with oem plugs and did you check the gap?
Sean
Old 03-18-2013, 07:13 PM
Color: silver
the guy at oreillys gave me the one up from the oem champion plugs because they were out of stock.i beleive the gap was okay no problems there.just a rev issue.do you think i should have got the oem plugs from somewhere else
Old 03-18-2013, 07:18 PM
snrusnak's Avatar
Rep:1388
Always go with oem. Surprisingly non oem plugs can sometimes cause real severe running issues. I'm not sure it'd be so bad it wouldn't rev past 1000 rpm, but either way proper plugs will run better. What exactly is "one up"? What material?
Are you sure all wires are fully seated? I think that engine has coil on plug so there's not really a wire but still the coils need to be fully seated.
Sean
Old 03-18-2013, 08:22 PM
CharlieHustle24's Avatar
CharlieHustle24 CharlieHustle24 is offline
Vehicle: 2008 Dodge Ram 4.7L
CharlieHustle24 is on a distinguished road
O'reilly's has been wrong on more than one occasion for me.
This break down helped big time. I actually changed the wrong plugs the first time!
CAUTION:
This engine uses TWO DIFFERENT types of spark plugs. A total of 16 plugs are used. The plugs are mounted in two rows (banks). The upper row (5) is used on the [COLOR=green !important][COLOR=green !important]intake[/COLOR][/COLOR] valve side of the cylinder head (Replace after 30K miles). The lower row (6) is used on the exhaust valve side of the cylinder head (Replace after 100K miles). The upper row (5) uses Bosch Nickel Yttrium plugs. The lower row (6) uses Bosch Iridium plugs. DO NOT INTERCHANGE THESE PLUGS.
Old 03-18-2013, 09:02 PM
Color: silver
the one up was not the champion plugs that are recommended to use but they were the ones that were around the same price.but lesson learned use oem and dont listen to the salesman.you are right they are coils and i will check to see they are seated properly.thanks to everyone for all their help
Old 03-19-2013, 10:00 AM
snrusnak's Avatar
Rep:1388
FYI the info posted above is for a 2008+ 4.7L, you have a 2005 so it's different. The info posted above is for the 4.7L with 2 plugs per cylinder, your 2005 only has 1 plug per cylinder.
The plugs may be your problem, I just read the 4.7L plugs have a copper ground electrode and if changed with a non oem plug can cause preignition(sounds like what may be going on with your engine).
4.7-L V8 (2005-2007)
Type: RC12MCC4
"Fired in suppressor seal" spark plugs using a copper core ground electrode.
OEM P/N SPRC12MCC4
(formerly 56028236AA)
MSRP: $3.70 ea.
.040 in. gap
3/4" reach, 5/8" Hex head
Torque to 20 Ft. lbs.
(NOTE: The 4.7L V–8 engine is equipped with copper core ground electrode spark plugs. They must be replaced with the same type/number spark plug as the original. If another spark plug is substituted, preignition will result.)
Sean
Old 03-19-2013, 02:50 PM
Color: silver
you are right sean having non oem plugs just messed up my truck.thanks for the info.
another question is that i did not put antiseize on the threads or put di electric grease inside the coil boots.would this have anything to do with the low rev problem
Old 03-19-2013, 02:52 PM
snrusnak's Avatar
Rep:1388
No that shouldn't effect how it runs.
Sean
Old 03-19-2013, 03:37 PM
02 Ram 02 Ram is offline
Vehicle: 2005 Dodge NSRT-4
Color: PX8
Rep:67
02 Ram will become famous soon enough
i didnt use any of that either when i did mine. i used champion 439's and the box said no need to use antiseize on the threads
2005 Dodge NSRT-4
