Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Suspension
Old 03-17-2013, 02:28 PM
madmatz madmatz is offline
Vehicle: 2004 Dodge Ram
Trim Level: sport
Color: dark grey
madmatz is on a distinguished road
Question Vibration is driving me crazy
i have a 2004 ram 1500 4x4. when accelerating there is a vibration coming form the drivetrain. when i let off the gas the vibration stops. the ujoints look good, but when shifting back and forth from drive to reverse there is a small clanking noise coming from the rearend/drive shaft. does anyone have any ideas what the problem could be?
Old 03-17-2013, 05:06 PM
CTEMT CTEMT is offline
Vehicle: 2003 Ram 2500 HD
Color: RED
Rep:13
CTEMT is on a distinguished road
it sounds like ujoints to me. grab ahold of the drive shaft and try rotating back and forth to check for play.
Old 03-19-2013, 06:10 PM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
they are cheap enough so you could just replace them..
Old 03-25-2013, 05:58 PM
hydrex's Avatar
hydrex hydrex is offline
Vehicle: 2005 QC 4X4 HEMI RAM
Trim Level: Thunder Road
Rep:427
hydrex is just really nicehydrex is just really nicehydrex is just really nicehydrex is just really nicehydrex is just really nice
Make sure the bolts thru the coupling are all tight. Probably U joints, though.
Inertia Spartan Plus cam, Circle D 3,000 rpm stall converter,Sonnax line pressure booster, MagHytec 68RE pan,and differential cover, Vararam, JBA's with cut outs, Rancho 9000's,3:92's, extra rear leaf.Line-X Bedliner,GY Armortracs, 210,000 miles To Hell and back. 14.2/96 mph NEDW
Old 04-22-2013, 12:59 PM
HemiDoug's Avatar
HemiDoug HemiDoug is offline
Vehicle: 2005 Dodge Ram 1500 HEMI 4x4
HemiDoug is on a distinguished road
make sure you check your rear differential pinion yolk nut.
