45-50mph shudder going WOT - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8
Diesel Forums!
Dodge Caliber
Place your Ad Here!
Old 03-17-2013, 05:28 PM
TORMENTOR TORMENTOR is offline
Vehicle: 2010 Dodge ram 1500 Hemi
Color: Deep Sea Water Blue
Rep:156
TORMENTOR has a spectacular aura aboutTORMENTOR has a spectacular aura about
Default 45-50mph shudder going WOT
So I've bounced around the forums, trying to find a proper fix for this issue but nothing solid yet.
Basically, my trucks had an issue when going WOT while cruising around 40-50 mph. Usually it only existed when the truck Wasnt fully warmed up but did pop up intermittently at times.
2 weeks ago, I took it to the dealer for the issue because I had ordered my Hemi fever tune and wanted to make sure this Wasnt something physically wrong in the tranny before installing it.
The dealer calls me back and says its fixed, that Chrysler released a PCM update to address this issue. So I pick it up and Tada! It's fixed, no more shutters and hunting for a gear and the torque converter deciding if it wants to unlock or not.
The issue after that though?, the truck seemed to have lost a lot of its "balls" it shifted so spongy, when holding it in 1st and punching it, you could feel it slip a bit before engaging, like they turned up the TM even more. Overall, it just Wasnt nearly as firm anymore. It felt like I was driving a prius.
So fast forward to this last week where I finally install the Hemi fever tune. WOW, trucks woken right up, more power from every rpm range, pulls like a freight train, BUT!! Guess what issue came back? And more prominent and aggressive then before.
And worse, it's consistent now, anytime I'm cruising around 50 mph, it shudders pretty bad for a few seconda and then the rpms shoot up and it goes.
What and the HELL is this trucks issue with this? I've seen this issue come up a lot for other owners, right now, Sean and I are trying to figure out how to work around this without having to put it back to stock shift points etc...
Btw here is a short video I got yesterday of what it does:
2010 Ram 1500 Hemi Crew Cab 4x4
Bilstein 5100's maxed out, 305/55/20 Cooper Zeon LTZ's, 14" Magnaflow, K&N Drop-in, DiabloSport InTune, HemiFever tuned
Old 03-17-2013, 09:02 PM
Phildo's Avatar
Phildo Phildo is offline
Vehicle: 2011 Ram Sport 4x4 QC
Rep:42
Phildo is on a distinguished road
Probably a torque converter issue. Could be slipping under wot gear changes
Old 03-17-2013, 09:13 PM
Rep:156
But why would the dealers PCM flash fix it? By turning up the TM?
Old 03-18-2013, 07:49 AM
ericlee9386's Avatar
ericlee9386 ericlee9386 is offline
Vehicle: 2011 Dodge Ram
Rep:36
ericlee9386 is on a distinguished road
I have this same issue. I added a 2800 stall and had Sean hold the gears longer and account for the stall in the tune and it cleaned up the shudder mostly. It still does it from time to time but I have been living with it until it gets figured out. I personally think its the trans skipping 3rd gear and not having the rpm or speed high enough. That's just my guess. Good luck
Performance mods
2800 stall, moes ported throttle body, vararam intake, ARH LT, Flowmaster 10 series, Hemifever tune.
Best 1/4 mile: 14.30 @91 mph soon to be 13's
Old 03-18-2013, 09:10 AM
catsltd catsltd is offline
Vehicle: 2010 RCLB SLT 1500 Ram
Color: Mineral Gray
Rep:72
catsltd will become famous soon enough
I would try it in tow haul mod.
I bet its fine.
The stock converter is junk,if your running one get rid of it.
2014-True Blue SLT,CC 6.4 BOX.
Air suspension,Rambox,Navigation.Backup camera.
3:92 gears.
Old 03-18-2013, 02:03 PM
Rep:156
I will try the tow/haul mode
Thanks
Old 03-19-2013, 10:10 AM
S.C. Express S.C. Express is offline
Vehicle: 2012 Ram Express
Rep:63
S.C. Express will become famous soon enough
Sometimes I swear mine will skip 2P and go from 2nd to 4th at those speeds. Italmost bogs because of the massive ratio change. Does it do it if you shift it manually?
Jones MaxFlow 18" muffler swap, Green Performance drop in air filter..
Old 03-19-2013, 07:23 PM
Rep:36
Mine won't do it if I shift it manually but I don't like doing that all the time. I wish the skip could be tuned out if the programing
Performance mods
Old 03-19-2013, 11:16 PM
Rep:156
I emailed Sean about it to see if there is anything that he can for it
Old 03-19-2013, 11:17 PM
Rep:156
Regardless of this issue that i know is no fault of Sean's since it existed well before the tune. His custom tune is amazing, im shocked at the difference in performance, even between the diablo one and his
