Before going all out - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8
Old 03-17-2013, 09:01 PM
Ryan Landis Ryan Landis is offline
Vehicle: 2008 Dodge Ram 1500
Ryan Landis is on a distinguished road
Default Before going all out
Hey guys, alight so before I start doing some serious mods I want to talk about what I should do to the truck before hand so it can handle the power. Should I get an upgraded differential a torque converter stall. Any help/suggestions would be great. Thanks.
Old 03-17-2013, 09:24 PM
Rep:3347
You need to ask yourself some very important questions and give us the answers before we can really say what you'd need to upgrade. Saying 'serious upgrades' to me is going stroked, blown, and bottle fed; to others it could be just cam and heads.
What is your desired power range to the rear wheels? How do you plan to make it: N/A, boost, nitrous? How much are you willing to spend? Do you have the time/shop space or a good shop near by? Will this be a DD/weekend warrior, strip or track, just a bit more under the pedal?
Old 03-17-2013, 09:43 PM
Alright iguess I should have worded that a lot more carefully, exhaust TB diablo tuner w/hemifever tune are the next thing I want to be doing.
Old 03-17-2013, 09:53 PM
TheSatinPumpkin's Avatar
Vehicle: 2004 Dodge Ram
Color: Satin Orange
Rep:627
you are going all out. depending on driving habits your oem drivetrain should be ok. i would check your u joints every now and then for play. Regardless if you are stock or modded i would inspect your clutch retainer clips if you have a oem LSD.
Old 03-17-2013, 10:00 PM
Rep:3347
For those mods you can leave everything alone. Even if you add headers you won't have to make any changes to the drivetrain. If you want to see a change to the drivability and make power higher in the band then you could swap to a different torque converter, but you won't be gaining much.
Old 03-17-2013, 10:03 PM
Alright I had thought that as well I had just heard a lot of bs from some guys I know that I would have to upgrade the drive train or I would tear it all up with these mods, thanks a lot for your guys's input
Old 03-17-2013, 10:08 PM
Rep:3347
You were the victim of
The tranny will hold 400hp, but beyond that you are definitely in the realm of a upgraded tranny or valvebody.
Old 03-20-2013, 12:30 AM
hodgeee's Avatar
hodgeee hodgeee is offline
Vehicle: 2012 dodge ram 1500 2x4
Trim Level: express
Rep:134
hodgeee will become famous soon enoughhodgeee will become famous soon enough
Ok, I researched a lot about the truck, cause I wanted 500+hp truck and wanted to run mid 12's in the quarter, this would fit me fine and give me all the performance I need to even expect with the truck without spending over $10,000. I have always upgraded the componentry first before doing my mods. I have had several over 450hp applications in the past when 450hp was considered a lot. Not so much in the last 10 years. I have blown a lot of money replacing drivetrain and motors.
Stock block has seen 650hp without reinforcing the block, this is not as high as I have seen, but as high as I have seen with 80,000 miles of use on it. I have seen a couple 750hp to 850hp hemi's out there, but many have gone through trannies, and diffs, driveshafts, motor mounts and cracked blocks. Although remember that any of this is still a gamble so keeping a safety level in mind is always smart, along with an extra $5000 of cash set aside, JUST IN CASE, unless this isn't your primary vehicle. They do make some all steal racing blocks now for the newer generation hemi's that are made for 850+hp. With stock pistons, guys are running 600hp with nitrous setups, but I have been seeing a trend of supercharger guys blowing out pistons, with only 150hp increases, but they have alwasy said with this motor supercharging is not recommended entirely due to the low weight racing style pistons. This is directly from Chrysler about the pistons! If you are planning on supercharging, either make sure you get one with a motor warrenty, like Edelbrocks, or Magnuson offers or change out your piston. If you have a 2wd motor, I heard that a couple of shops can change out the pistons from underneath after removing the oil pan, just like in a lot of the LS platform motors. Haven't verified this! Yes you can change out the cam without removing the motor,
Tranny, with torque converter upgrade and valve body stage 2 upgrade, guys have been running consistant 500hp+ levels with years of trouble free driving. I have heard you will burn out the clutches in the tranny if you start running over the 500hp mark and either dont tune for maximized tranny pressure and quick shift speed, or do the valvebody upgrade which will give you the same results as the tunning! If you are up to or above 600hp levels, they offer stage 2 and 3 trannies with stronger planatary gear setups and blue plate special clutch plates, plus you will want an all billet converter, and a heavier solid Flex plate, ours are actually spaced for lighter weight. But for the most part I have seen 600hp applications running the stock tranny fine, mostly the clutches that are designed to take up the slack are what go, so not many blown trannies, just burnt out clutches, a lot cheaper to rebuild this way. This has been a great tranny for Chrysler, especially when they don't break down very much, and they are used in soo many vehicles. Since 2006 and 2009 the trannies each time also recieved internal upgrades that have made them stronger, so 2009 and up versions are the strongest ones in the pack.
Driveshafts, unless you are running very high speeds, then go with a light weight balanced aluminum, otherwise no probelms I have able to find in research.
Differentials, we know in 2011 and newer models, that they went from the 9.25Chrysler diff to the ZF manufactured diff. I have seen side by side pictures of the two, and the ZF has a little bit bigger webbing and a slightly thicker housing. According to Ram, the same diff is used on the basic 2500 truck with Hemi, and many heavy towing guys over the years have complained about leaking and chewing up of teeth on the Chrysler diff, leading Ram to us the ZF diff which is rated at 22% stiffer housing for less flex, less chance of gears eating up eachother with also leads to less chance of seals leaking. So stronger and same price point. I have not heard squat beyond this about the rear diff problems from anyone, but you can get larger splined axles, and they do make billet end caps, with ARP studs, also they have steel reinforced back plate that stiffens the whole housing and has main cap stabilizing bolts, just like those diff cover plates they used on high hp Mustang and Camaro rear ends but this is on the Chrysler diff. So most guys I have seen running fast ass trucks are just using the stock rear end. And I have seen one guy running mods plus a lot nitrous blow up his driveshaft at 120mph when the truck shifted, this was later found out to be, not balanced to high rpms which caused it to blow when shifting into 4th gear at 120. No problems with new driveshaft.
Cooling system, stock setup on 700hp applications no problem. Fuel upgrades over 550+hp applications recommended larger fuel pump, or injectors depending on setup, Coils are good to 850hp applications, I have only seen some guys use a MSD control box that help boost the stock coils. Fuel lines, stock lines using larger fuel pump and injectors or fuel booster good up to 850hp.
Now most of the components that hold the rear end are much much stiffer than the bent sheetmetal that they like to use in the mustangs and camaros of old. Our links are tubular, with solid mounted pivot points, plus the panhand rod, are pretty damn stout. If you have taken apart this supension doing a lift or lowering you will see what I mean, no need to upgrade any of these parts beyond stock. It will handle most anything you will throw at it. Of course once agian, if you are running a 700+hp setup, than everybit helps, so, spohn makes heavy tubed adjustable control arms for this rear end, and I would recommend a custom shop weld some support plates on the frame link spots. This would reduce the amount of flex nicely on the rear end. The mounting points on the rear diff itself are pretty freakin stout, so no recommendations for anything there.
So in other words, if you are doing just all basic bolt ons, intake, headers, exhaust, t/b, tuning then the stock setup is completely fine and will handle this no problem. Hell I have driven a stroked and supercharged fully stocked bumble bee truck with 700hp, and that was a little bit of a handfull, and was built to handle the power, but he did not have the benifit of our 4 link, for better tractions, stability, ride, and handling, like ours.
So NO worries ladie!!! Now what is messed up, go buy anyone elses truck or cars and start to mod them, and THEN see how much you gotta spend.
BellTech 2/4 Street Performer, Spohn PanhandRod, Hellwig Sways, Volant Intake(Donaldson Filter), 85MM Fastman Throttle body, 14" Magnaflow, T1000 w/Hemifever Tune, 180 T-stat, 4.10 Gear Swap, Edge Street Perf - 2600 Stall, Billet Catch Can, E-Fan Swap, ARH LongTubes
Old 03-21-2013, 05:12 PM
Chris b's Avatar
Chris b Chris b is offline
Vehicle: 2012 RAM
Trim Level: R/T
Rep:312
Nice write up hodgeee....
SPONSORED BY
BULLY'S PERFORMANCE
Old 03-21-2013, 05:42 PM
dusterman dusterman is offline
Vehicle: 2012 ram reg cab express
Rep:79
dusterman will become famous soon enough
Is was like when I saw the book like reply. But after I read all of it I give yah
Performance:K&n cai, muffler delete, ported throttle body, 2800 edge stall 180t and white lightning tuning : soon longtubes
Interior: painted inserts, clazzio leather kit.
