United Radio
Old 03-18-2013, 07:06 PM
Yotaman96 Yotaman96 is offline
Yotaman96 is on a distinguished road
Originally Posted by BWG56 View Post
The problem with your battery going dead might be because the computer does not recognize it and it continues to search for it instead of going to sleep. I had the same problem with my battery going dead after I had installed an OEM brake controller. The computer did not have it in its program and it would keep searching for it. If you change the radio I would think you would have to take it back to the dealer and have them reflash the computer with the vin# + the radio code.
One of the PDFs mentions assigning it to my VIN. The dealer said it shouldn't matter, but there's a lot they don't know.
2010 Ram 1500 Crew Cab 4x4 Sport
Old 03-18-2013, 09:41 PM
BWG56's Avatar
BWG56 BWG56 is offline
Color: Mango Tango
Rep:19
BWG56 is on a distinguished road
It took my dealer a couple days to figure it out and once he added the brake controler code to my vin# and down loaded it to my truck it cure the dead battery and now the EVIC recognizes it also. I'll bet if the dealer would try it, it would solve your problem. These vehicles are only programed with the options included with the truck. The computer is smart enough to know something is hooked up, but can't recognize what it is if its not in the software and will continue to search for it.
The dealer did charge me like $85 to upload the brake controller code but I thought it was worth it.
Old 03-18-2013, 10:22 PM
I remember having to explain to them how to add the trailer brake controller to my VIN too. At the time, they had no idea it could be done.
Old 03-22-2013, 01:26 PM
Iqudayo's Avatar
Iqudayo Iqudayo is offline
Color: Mineral Gray Metallic
Rep:563
So how did you add the brake controller... hmmmm
Old 03-22-2013, 04:01 PM
I had the harness under the dash. Plugged it in and it worked. Had the dealer add it to the vin and the info showed on the dic just like it would as a factory installed piece.
Old 03-24-2013, 09:42 AM
astroman54's Avatar
astroman54 astroman54 is offline
Rep:52
astroman54 will become famous soon enough
The problem with the GPS not working may be this:
I believe that the 2011 model year, Dodge began putting a combined Sirius/GPS antenna on the truck. In 2010 I believe it was separate antennas. You may want to swap out the roof antenna with a newer one. I had to do this when I put an RHR radio in my 2009.
Andy
Andy
2009 Dodge Ram 1500 Sport Deep Water Blue Crew Cab Hemi 4x4
Old 03-24-2013, 10:02 AM
Andy
That's exactly what I was thinking. Thank you.
Old 03-27-2013, 07:22 PM
magiaone magiaone is offline
Vehicle: 2010 Ram
magiaone is on a distinguished road
Correct for 2011 upwards the antenna was combined with the Sirius roof mount for the RHB and RHR. The RER still uses the nav antenna in the upper instrument panel.
