Toyo AT II "EXTREME" - But rubs a bit. - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Diesel Forums!
Dodge Caliber
Place your Ad Here!
Old 03-18-2013, 04:33 PM
Tim28's Avatar
Tim28 Tim28 is offline
Vehicle: 2010 Dodge Ram Laramie Quad Ca
Rep:47
Tim28 is on a distinguished road
Default Toyo AT II "EXTREME" - But rubs a bit.
Hey boys. So I just had a new set of 305/55/20's put on the stock rims. I have the Blistein level at 2.1 and I'm getting a bit of rub at full left lock. Les Schwab is recommending a new set of rims with a 25 offset. There has to be a cheaper way to get the right offset besides dropping another grand on a set of rims.... Suggestions? (yes now I have the EXCUSE for rims, but I'd rather not just right now).
Incidentally, the open country AT II look great. I think they're a good balence between an AT and the MT. I'll see if I can get some pics up soon....
Thanks in advance!
*Someday I'll have enough posts to have a real signature*
Old 03-18-2013, 04:57 PM
brandonjansen's Avatar
Moderator
Trim Level: Laramie Limited
Rep:2140
Two words: Wheel spacers! Order up some 1/4" wheel spacers and you'll clear them no problem.
I'm pretty sure your stock rims are a 25 offset anyway, so buying another set of those isn't going to solve anything....
Old 03-18-2013, 05:31 PM
Tim28's Avatar
Rep:47
If they're already a 25 offset wouldn't adding a 1/4 spacer solve the problem? Maybe I'm missing something.
Old 03-18-2013, 05:36 PM
Tim28's Avatar
Rep:47
Here are the photos of the new tires. So far pretty impressed. A touch louder than expected but I like the look.
Old 03-18-2013, 05:56 PM
vino350's Avatar
vino350 vino350 is offline
Vehicle: 2012 Dodge Ram 1500 4x4
Trim Level: Hemi Express
Color: True Blue Pearl
Rep:15
vino350 is on a distinguished road
ive been thinking about gettin the xtremes thanks for someone finally getting a set on a 4th gen ram..and posting pics..i love the toyo mts but i do alot of highway driving and not sure i would like em..the ats look great though glad you like em post up more pics if u can maybe a front wheel turned out pic
Old 03-18-2013, 06:02 PM
Gantman's Avatar
Gantman Gantman is offline
Vehicle: 2016RCLB4x4/44-45
Trim Level: Tradesman w/3.92 LSD
Rep:999
Hey Tim28, you could try these spacers that look very strong.
Total Chaos UCA's, Fox 2.0 IFP Coilovers and shocks, TTC-1223V variable rate coil springs.(Mods list)
Old 03-18-2013, 06:03 PM
Danimal77's Avatar
Danimal77 Danimal77 is offline
Vehicle: 2015 RAM 1500 CREW
Color: Maximum Steel Metallic
Danimal77 is on a distinguished road
Those suckers are supposed to be real heavy. Any noticeable loss in power?
2015 RAM 1500 Sport CC 4X4 Maximum Steel Metallic
Old 03-18-2013, 06:05 PM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
Thanks in advance!
Isn't stock offset like 19? Wouldn't 25 make them tuck in even more? Isn't that why u are rubbing
Old 03-18-2013, 06:06 PM
Moderator
Rep:2140
Yes, that's what I was saying. Just add a 1/4" spacer to your factory wheels and you will clear the tires no problem. Les Schwab recommending an aftermarket wheel with a 25 offset doesn't make any sense because you'd still have to run a 1/4" spacer with those. You'd want a 12 or 0 offset on an aftermarket rim for the set up to work properly.
Old 03-18-2013, 06:09 PM
Grubrunner's Avatar
Rep:3883
I thought the OEM's were 18mm offset.....
Grub out!
