Old 03-19-2013, 03:10 PM
HOTRODHARLEY's Avatar
HOTRODHARLEY HOTRODHARLEY is offline
Vehicle: 2013 Ram factory order
Color: BLACK
Rep:256
HOTRODHARLEY is a jewel in the roughHOTRODHARLEY is a jewel in the roughHOTRODHARLEY is a jewel in the rough
Default Moroso Air Oil Separator Ordered
I see a ton of BT catch cans on here. But I've chosen to use a MOROSO Air/Oil Separator Part no. 85496 Yes it's a universal one and I will make my own brackets as needed.
Has anyone else on here used one on their 4th Gen Hemi..?
Belltech 3"/5" Lowering kit. Belltech Rear Swaybar, Flowmaster Y Pipe, Custom 4" Single Exhaust w/ 4" Race Magnaflow, 22" SRT10 Wheels, Moroso Catch Can, Undercover SE Tonneau Cover, Weathertech Techliner Bedliner, Diablosport Trinity w/ Hemifever Tune
Old 03-19-2013, 09:26 PM
jrtz80's Avatar
jrtz80 jrtz80 is offline
Vehicle: 2012 Dodge Ram
Color: Tequila Sunrise
Rep:51
jrtz80 will become famous soon enough
I have the Moroso 85472 and one of the brackets that came with it worked absolutely perfectly. I've owned and like the BT catch can but I love the Moroso because of the incorporated drain valve. Build quality is excellent and it is chambered like the BT as well.
180 Tstat, Solo CB, Moes 85 TB, S&B CAI, Catchcan, Hemifever, Airlift, Kicker audio, SmartStart.
Old 03-19-2013, 09:41 PM
JS1500 JS1500 is offline
Vehicle: 2012 1500
Trim Level: Big horn
JS1500 is on a distinguished road
I have it and the only problem I have had with it is the drain freezing up. I am in Minnesota and I see you are in Canada so you may run into the same issue. If you run the engine for a while before you drain it the engine heat is usually enough to thaw it.
Old 03-19-2013, 09:50 PM
jrtz80's Avatar
Rep:51
Yeah, I've never tried to drain it in the winter before I warm it up a bit.
Old 03-19-2013, 11:29 PM
ironchef2011's Avatar
ironchef2011 ironchef2011 is offline
Vehicle: 2012 R/T
Trim Level: R/T
Rep:120
ironchef2011 will become famous soon enoughironchef2011 will become famous soon enough
I have a Moroso that was actually made for the fourth gen Ram. I got it from Summit Racing and used it for 40K on my previous Ram and now on my new one. Great product, perfect fitment and still looks like new today.
2012 R/T 392
Old 03-19-2013, 11:38 PM
Bully's Performance's Avatar
BULLYS PERFORMANCE
Vehicle: MOPAR
Rep:931
Anyone looking for Moroso catch cans let me know we can get you the lowest pricing around
Thanks
Jeremiah
Discount Auto Performance
Old 04-22-2013, 11:57 PM
HorseMan's Avatar
HorseMan HorseMan is offline
Vehicle: 2014 6.4 Hemi; traded 2013 CTD
Trim Level: Laramie Crew 4x4
Rep:139
Sorry to bump an older thread, but I ordered the Moroso for my new 13 with 8 speed. Will fit, but it came with no directions. I have no idea how to put the thing on. Anybody get step by step directions? Please help...I can't believe it came with no directions!
2014 2500 Laramie Crew 6.4 Hemi, 4.10 axle
2013 RAM 2500 Laramie Longhorn, Cummins, Western Brown (traded)
Old 04-23-2013, 12:12 AM
Judd McPherson Judd McPherson is offline
Vehicle: 2013 Ram Sport
Rep:192
Judd McPherson has a spectacular aura aboutJudd McPherson has a spectacular aura about
HorseMan,
Call me at (417) 438-8880 and I will walk you through it. It was easy once I took the engine cover off.
Old 04-23-2013, 07:32 PM
Ronan's Avatar
Ronan Ronan is offline
Vehicle: 2013 ram sport crew
Trim Level: Sport crew
Rep:42
Ronan is on a distinguished road
Just installed mine today, took only about 15 min, very easy. Take a look at the pic and it says it all. It may be different on the 8speed. But still simple. Looks great and appears to be easy to drain. Got mine from DAP.. Thanx fellas!!
Vararam CAI, Moes 87mm, flowmaster ,20x9 DC gun metals, 325/60/20 Terra's , bilsteins set at 2.1 , access tonneau, raptor W2W nerfs, AVS ventvizors , tints.........
Proud member of LOCAL 361 IRONWORKERS
Old 04-24-2013, 11:01 PM
topgun's Avatar
topgun topgun is offline
Vehicle: 2012 Ram 2500 CC 4X4
Trim Level: Outdoorsman
Rep:71
topgun will become famous soon enough
The instructions for these are on Moroso's web site, down near the bottom of the page. The 4th gen Ram truck specific part # and install instructions are #85479. Others may work but this one has the correct mount for 4th gen Rams.
#85479 Dodge Truck 5.7 Engine, 2009 & Up
http://www.moroso.com/catalog/catego...?catcode=18549
Undercover SE, Corsa Cat Back, Amp Powersteps, Amp Bedstep, Bedrug, Mopar Tailgate Lock, Mopar Fold Flat Floor, Mopar Flat Rubber Splash Guards, Cooper AT3 285/70/R17's, S&B Intake, Moroso Catch Can
