Steering Pull or Jerk - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 03-19-2013, 06:17 PM
otorongo otorongo is offline
Vehicle: Dodge Ram 2500 2005
otorongo is on a distinguished road
Default Steering Pull or Jerk
Hi, I have a problem with my dodge 2005 Ram, 2 wheel drive. The problem is I have a jerk when I go over bumps, even small slow bumps. It feels like a steering dampener or stabilizer gone bad, but I know my truck doesn't have a dampener because it is rack and pinion. At the dealership they put new rack and pinion, new upper control arms, new ball joints, new shocks, and the tires are fine. I also looked at the lower control arm bushings and they are okay. I still have the same jerking feeling. The service advisor told me that there is a dampening valve built into the steering box and the tech told me that there is No valve. So I don't know who to believe. Please let me know if anyone has run into this problem and/or knows anything about it. Thanks!
george
Old 03-27-2013, 04:49 PM
age525's Avatar
age525 age525 is offline
Vehicle: 2006 Dodge Ram 1500
Rep:91
age525 will become famous soon enough
Is there any looseness in the steering? I know in my truck the steering was loose and it would cause it to jerk a little over bumps. nobody could find anything wrong for a while but i found out that there was a u joint connected to the steering rack which was bad. replaced that and everything was ok.
S&B Cold Air Intake, American Racing Headers, DB Performance Cat Back Exhaust, Recon LED Taillights, Bilstein 5100's, Toyo Open Country AT 2, Diablosport Predator, Recon Line of Fire, JL Audio 10W3 StealthBox, Alpine iDA-X305s Head Unit, Detroit TrueTrac
Old 03-27-2013, 05:04 PM
Rep:2929
It could very well be a part in your steering shaft assembly
http://www.borgeson.com/xcart/catalo...ab-p-1458.html
Old 02-07-2014, 09:35 PM
Lwoodsmopar Lwoodsmopar is offline
Vehicle: 2003 Ram 2500, 2004 Ram 1500
Color: 2003 Almond, 2004 Red
Lwoodsmopar is on a distinguished road
I have had my 2003 Ram 2500 2WD since September 2002 and it's done this since day one. It now has 40,000 + miles and would have more if it drove better. What is happening is when you hit a pothole or bump in the road, the front tires are bouncing off the road, freeing any resistance the tires have when planted firmy on the road. If you're going straight, it's not as bad as when you're driving through curves while turning the steering wheel. Hitting a pothole or bump on a curve at speed is scary at best. It needs a stabilizer shock on the steering, but as you noted, it's a rack and pinion and there's no where to add one.
I found the best improvement to date was installing Billstein shocks. They seem to keep the tires planted better than the stock shocks (replaced @ 20,000 miles) or the Rancho shocks (replaced @ 40,000 miles). I just installed the Bilsteins last year. I told my wife if the Bilsteins didn't help, ten years of this was enough.
steering stabalizer, steering wander
