Diablo Intune and gear sizes. - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8
Old 03-20-2013, 11:36 AM
Canadian Hemi Pride's Avatar
Vehicle: 2008 Dodge Ram 1500
Trim Level: SXT 4x4
Color: Silver/ Black
Rep:2826
o yes...no issues with spinnin tires now and goin to 35's your drivetrain will love you more for the less stress on it
I already have no trouble spinning tires.. but think that is because of the garbage wranglers.
That is a good point about the drivetrain... Well time to start working every second not in school -.-
IG:@briley59
Old 03-20-2013, 11:37 AM
ShawnC13's Avatar
ShawnC13 ShawnC13 is offline
Rep:2055
ShawnC13 has a reputation beyond reputeShawnC13 has a reputation beyond reputeShawnC13 has a reputation beyond reputeShawnC13 has a reputation beyond reputeShawnC13 has a reputation beyond reputeShawnC13 has a reputation beyond reputeShawnC13 has a reputation beyond reputeShawnC13 has a reputation beyond reputeShawnC13 has a reputation beyond reputeShawnC13 has a reputation beyond reputeShawnC13 has a reputation beyond repute
I submitted for a build sheet.. So hopefully I will have my answer soon.
I had a few issues getting mine at first as I bought it used and wasn't the registered owner, they gave me a number to call and I became the registered owner with Chrysler and now any recalls or anything like that they will notify me. If you don't hear back do it again and they might give you a number to call. I had it and pm'd it to a member before but I have cleaned out the private message sent box since. I see you are an 08 SXT, that is the trim level on my 08 TRX4 which is 3.55's so unless it was ordered with the 3.92 I am thinking it went to dealer as basic. Let me know if there is anything else I can help you with I will try and find the info I have as well.
Old 03-20-2013, 11:40 AM
Trim Level: SXT 4x4
Rep:2826
Yeah I had to register it under an american address for one.. and this truck was one of my dads company trucks since new, so i will prob have to call the number to find out.
So yeah I most likely have 3.55's, that is weird that the TRX4 would have that, think they would make them bigger just to prepare for bigger tires, because that is the offroad package?
IG:@briley59
Old 03-20-2013, 11:50 AM
ShawnC13's Avatar
Rep:2055
Here is my build sheet and wheels are stock 17's
Please find attached, as you requested, the original factory equipment list of the subject vehicle at the time of manufacture, according to our records.
Thank you for the opportunity to be of assistance to you.
Cloth 40/20/40 Split Bench Seat
Med Slate Gray
SXT Appearance Group
Trailer Tow Group
TRX4 Off Road Group
Monotone Paint
136 Amp Alternator
750 Amp Maintenance Free Battery
4 Wheel Disc Rr Anti-Lock Brakes
Rear Folding Seat
Front Height Adjust Shoulder Belts
Advanced Multistage Front Air Bags**
Front Seat Area Carpet
Front & Rear Floor Mats
Passenger Assist Handle
Rear Underseat Compartment Storage
5-Spd Automatic 545RFE Transmission
Elec Shift-on-the-Fly P/Time T/Case
205MM HD Front Axle
3.55 Rear Axle Ratio
Corporate 9.25 LD Rear Axle
Anti-Spin Differential Rear Axle
5.7L V8 HEMI MDS Engine
Tinted Glass Windows
Rear Fixed Window
Rear View Day/Night Mirror
Power Black Trailer Tow Mirrors
All Vehicles W/Power Mirrors
Remote Keyless Entry
Sentry Key Theft Deterrent System
Air Conditioning
Dash Liner Insulation
Floor Tunnel Insulation
Instrument Cluster w/Tach
Instrument Panel Black Bezel
200 KPH Primary Speedometer
Var Intermittent Windshield Wipers
Cigar Lighter
Dual Note Electric Horns
12V Auxiliary Power Outlet
Power Accessory Delay
Power Locks
Power Windows, Driver One-Touch
Manual Adjust Seats
Tire Pressure Monitoring Warning LP
Halogen Headlamps
Daytime Running Headlamps, High Beam
Fog Lamps
Cargo Lamp
Bright Rear Bumper
Gray Upper Fascia
Bright Front Bumper
Front License Plate Bracket
Bright Grille
Ram's Head Badge
Removable Tailgate w/Caliper Latches
Front Air Dam
TRX4 Off Road Badge
Federal Emissions
26 Gallon Fuel Tank
Auxiliary Transmission Oil Cooler
Engine Block Heater
Speed Control
Electronically Controlled Throttle
Heavy Duty Engine Cooling
Next Generation Engine Controller
Flame Red Clear Coat
All Radio Equipped Vehicles
4 Speakers
Fixed Long Mast Antenna
AM/FM Compact Disc Radio
Sirius Satellite Radio
Power Rack and Pinion Steering
4-Spoke Steering Wheel
Front Heavy Duty Shock Absorbers
Rear Heavy Duty Shock Absorbers
Front Stabilizer Bar
Tilt Steering Column
Full Size Spare Tire
Tire Carrier Winch
P265/70R17 OWL On/Off Road Tires
Goodyear Brand Tires
17" Steel Spare Wheel
17" Aluminum Wheels
All Aluminum Wheels
Center Hub
Non Adjustable Pedals
Tip Start
Pickup Box
Tow Hooks
Transfer Case Skid Plate Shield
Front Suspension Skid Plate
Class IV Receiver Hitch
7 Pin Wiring Harness
Trailer Tow w/4-Pin Connector Wiring
Stain Repel Seat Fabric
English/USA Language
Instrument Panel Parts Module
Tire & Wheel Parts Module
For More Info, Call 888-539-7474
1-Year Service Provided by SIRIUS
Build To Canada Mkt. Specifications
Old 03-20-2013, 12:06 PM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
i have 3.92s and 35" M/Ts and I can definitely feel the change from stock tiers. But i can still break them loose any day. I think regearing is on the order of a thousand or two. I only found out my gears when I put my superchips on and it told me in the vehicle info in the settings.
Trim Level: SXT 4x4
Rep:2826
There are some features I can tell that are different from mine to the TRX4.. mainly hooks, skid plate.. also don't beleive i have rear locking dfferentals.. but hopefully I get my sheet soon so I can get this figured out.
IG:@briley59
Old 03-20-2013, 12:12 PM
ShawnC13's Avatar
Rep:2055
Yeah those are some of the Off Road features, that and I am told there is a bit of difference in the suspension.
Old 03-20-2013, 12:24 PM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
I've run 4.56's on 31" 17's and absolutely loved the street manners... they finally went bad and i swapped in my stock 3.92's and I sorely miss the 4.56 feel...
Old 03-20-2013, 01:09 PM
ShawnC13's Avatar
Rep:2055
Did the 4.56's hurt highway mileage? I am sure it wouldn't affect the city to much but wondering about the Highway.
Old 03-20-2013, 01:10 PM
chefred112's Avatar
Rep:656
I was still in to 20's for mpg's...
