Old 03-22-2013, 05:56 PM
mrpositraction mrpositraction is offline
Vehicle: Ram 1500 Sport Crew
Rep:95
mrpositraction will become famous soon enough
Originally Posted by Nemmisis1 View Post
No problem running 55w in the projector? Also I think I'm going with a 55w canbus 5k kit... Low beams and fogs.... What r ur thoughts? Also know any place where we can get a decent price for them besides retro and gtr?..... 200 a kit is high. I have seen kits on eBay 55w decent kits for 100-125 bucks canbus non the less...
I don't know much about the canbus kits, but stay away from the cheap ebay imitations. I purposely bought a cheap set and a **************** kit about a 1.5 years ago to compare quality. The difference starts from you open the package and the light output quality was night and day.
I ran **************** in three of my vehicles in the past (including my current) and haven't had one issue. I love them.
2013 F150 Ecoboost SCrew FX4
5* Tune, AFE 2 Intake
Old 03-22-2013, 06:13 PM
Asur Asur is offline
Vehicle: .
Rep:4373
Originally Posted by Deathstalkr View Post
Asur,
Can you link or PM the link to the blubs you used. I'd be interested in buying them given your input.
Can anyone tell me the difference in lighting. I've read on this topic multiple times and it just confuses me for some reason. As I understand it, the sport comes with low beam projectors and high beams that aren't, correct?
Bottom line: Do I need to install a 'canbus' on my '13 sport with the projectors or is that only for the high beams?
Sorry for the highjack...
Mike
I use ****************, have bought over 12 kits from them and never had an issue, many use there kits here on the site, some with great results others with some issues. I serious have had no issues with them. Now that being said, I only heard of issues with some on the 2013, so I would check with them and confirm there kits are fully running on the 2013, email sales to the attention of Todd, they are slow answering cause they have about 300 emails a day for quarries. But they have been great for me up to date. There not cheap, but Ebay is give or take, you pay for what you get, My projectors are Morimoto D2S, I built my own headlamps, but all my bulbs and ballasts and wire-harnesses are ****************.
answers to your questions.
As indicated, I used other bulbs than those on the 2013, D2S is what I used, but the HID bulb you need is different for your projectors, check with
Todd, he will tell you the bulb you need.
If you have the projector headlamps, your lows are projectors (looks like a magnifier glass lens) and your highs are standards reflectors
each set you replace you can get either a canbus system or a wire harness system HID kit. I have only used a wire harness for replacing bulbs with HID's, some swear this is the best way because your running on your battery direct, other prefer and swear by the canbus system cause its less complicated to install. Some have other reasons. its really a personnel preference. I have a set of canbus as a spare in case.
So if you replace your fogs, your lows and your highs, your talking about 6 bulbs, 6 ballasts if your running canbus, and if you go wire harness, you will need 3 wire harnesses, you can also go canbus for your fogs, and wire-harness for your lows, etc. like I said, personal preferences.
Hopefully this gives you some info, you can go to ****************.net and check out there FAQ's, lots of great info in there to understand stuff.
End of the day, you pay for what you get, with 12 kits installed, and not one with an issue, I love my Retro's
Old 03-22-2013, 06:29 PM
Deathstalkr Deathstalkr is offline
Vehicle: 2013 1500 Ram Sport
Trim Level: Crew Cab
Rep:19
Deathstalkr is on a distinguished road
Thanks for the reply. I definitely need to do some more reading and figure out what would be best for my situation.
You cleared up some of the differences I was concerned about. Thanks again.
Mike
Old 03-22-2013, 07:51 PM
buckmaster buckmaster is offline
Trim Level: Laramie Longhorn
Color: Deep Cherry PearlCoat / White Gold
Rep:16
buckmaster is on a distinguished road
ASUR,
Do you get any error messages on you Evic? Like "headlamp out" using the Retro setup.
Old 03-22-2013, 07:55 PM
s1000rrhp s1000rrhp is offline
Vehicle: 2013 Dodge Ram
Rep:13
s1000rrhp is on a distinguished road
I run the canbus system only 35w don't need the hassle of 55w problems. Canbus system is nice for the 2013s because it is plug and play and you won't get errors on your evic
Old 03-22-2013, 07:59 PM
Vehicle: .
Rep:4373
Originally Posted by buckmaster View Post
ASUR,
No errors with my kit
Old 03-22-2013, 08:06 PM
Rep:16
Thanks for the input. I know where to buy the Retro setup because you have posted it before. Where can I purchase the Canbus system? I have seen several that are called Canbus including the some of the cheap ones listed on ebay. I agree that a relay with harness is needed as the ignition requirement for the hids can be 20 amps and they could be a strain on the OEM harness, switch, etc. Relaying it directly from the battery makes sense.
Old 03-22-2013, 08:59 PM
Rep:95
I keep hearing you talk about 55W problems. What are these problems you speak of?
I also have 2013 and don't get any error messages, I even posted a video to prove it. Also, the retro-solution is also plug and play, you cut no wires. They provide a harness that goes to the battery for direct voltage and that runs to the ballasts.
Isn't the Canbus system more expensive also? I thought I heard you say it was $250. I paid $145 shipped for my **************** kit shipped.
Old 03-23-2013, 09:43 AM
Vehicle: .
Rep:4373
You are correct, which is why I still prefer a wire harness, at the end of the day you wont burn out your plugs, or strain your switch etc, both 50/55 watt HID kits draw significant current, over 10 amps for almost 250ms, so lets say you install 6 canbus ballast, you going to draw for 250ms a shot to the OEM harness of 60amps, compared to halogen bulbs of maybe 25 - 30 amps. In 4 -5 years how much damage will it do to your OEM wire harness and switches. If you sell the truck or swap it in at the dealer, you can pull everything out, and just plug your old bulbs back up no issues, so its not like you have to hard wire anything, many think that cause your putting in a harness your hard wiring it into the truck and get Canbus plug in ballasts instead. Since I only bought one kit of canbus as a spare I picked it up on Ebay, I wanted to test it on my truck also. Its nothing special and have not run it more than for testing so I cannot give you a good link on where to get a great Canbus ballast. Now that being said, I would still check with Retro what they have come up with for the error message in the EVIC for the 2013's, by now they must of setup a kit that will not give this issue. Also it would be nice to find out from the Canbus people what there current draw is. My Canbus ballast indicates a 5amp draw on running but does not tell me my startup draw.
Old 03-23-2013, 03:06 PM
Rep:95
I HAVE A 2013, I HAVE NO ERROR MESSAGES ON THE EVIC
Is nobody reading this?
