Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Dodge Ram MPG Zone
Dodge Ram MPG Zone Discuss your MPG woes and helpful hints here!
Old 03-20-2013, 09:28 PM
powerram250 powerram250 is offline
Vehicle: 98 dodge ram. 318 5spd.
Trim Level: base
Color: red
powerram250 is on a distinguished road
Default 3 mpg
98 dodge ram 318 with a 5spd just bought it. 137000 miles. 305/70r17 on it x cab. Put 5 gallon it it and got 14.7 miles. Can't afford to drive it. Need help very badly
Old 03-21-2013, 09:25 AM
Resident Technician
Rep:1909
The first thing I see is the oversize tires - this makes me think your odometer and speedometer aren't calculated correctly. What gears are in this truck? Is the MIL on and are there any codes? Are the O2 sensors old or have they ever been changed? How about maintainance, has it been tuned up in the last 30k miles? Are you running fuel with ethanol in it, or 100% gasoline?
Old 03-21-2013, 03:04 PM
Trim Level: base
Color: red
Codes 133 and 171.
Old 03-21-2013, 03:05 PM
Trim Level: base
Color: red
Going to do a full tune up tomorrow to see if it helps along with the upstream o2
Old 03-21-2013, 03:08 PM
Resident Technician
Rep:1909
There you go. P0133 indicates a slow response from the 1/1 O2 sensor which is a primary sensor used for calculating the fuel curve. The P0171 indicates a lean condition which means the PCM will be trying to enrich the fuel mixture. Replace the upstream sensor, clear the codes and run a couple of tanks of fuel through it and track your MPG. You should see an improvement.
Old 03-21-2013, 09:49 PM
plumcrazy73's Avatar
plumcrazy73 plumcrazy73 is offline
Vehicle: 2013 Ram 1500 2WD Crew Cab
Trim Level: SLT w/Big Horn EQ GP
Color: True Blue Pearl
Rep:119
plumcrazy73 will become famous soon enoughplumcrazy73 will become famous soon enough
check and see if you have a gas leak
Old 03-21-2013, 11:12 PM
Trim Level: base
Color: red
Will do the upstream tomorrow and see hopefully it will improve a good bit. I have checked for gas leaks and have none. The k&n air filter is new. Oils been changed. So hopefully the o2 will fix most of the problem. Thanks
Old 03-22-2013, 09:06 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
Seems likely it's the O2 sensor. If it's still not running great after the fix you could try plugs/wires/etc, cheap tune up parts.
I believe coolant damages O2 sensors, so if the you get the same code shortly after the fix, you may have a coolant leak in the engine. Just a thought, I'm not positive it that error would be caused by this.
Sean
Old 04-12-2013, 11:59 PM
namretsud's Avatar
namretsud namretsud is online now
Vehicle: 15 BigHorn Ecodiesel
Rep:194
namretsud has a spectacular aura aboutnamretsud has a spectacular aura about
Could also have a bad plenum gasket leak.
Old 04-16-2013, 11:21 PM
friendlyHP's Avatar
friendlyHP friendlyHP is offline
Vehicle: 2004 Dodge Ram AWD
Trim Level: Laramie 4x4 quadcab
friendlyHP is on a distinguished road
sounds about right for that vehicle at that many miles though. Just listen to everybody's advice and remember the best fuel saver is your foot.
1992 Dodge Ram EFI 5.2 150 1996 Dodge Dakota Sport EFI 5.2 4x4
2004 Dodge Ram Laramie 4x4 (AWD)
