Old 03-21-2013, 02:00 AM
1fstrt 1fstrt is offline
Vehicle: 2012 ram r/t
1fstrt is on a distinguished road
Default Rear end shaking
Hey my name is Ryan I have a 2012 ram r/t lowered with the djm lowering kit. I installed the adjustable pan hard bar from spohn racing to correct the off cent axel issue. I got my trinity tuner and wanted to see how fast she cold go now and at 190km/h I had no choice but to slow down because I thought I was going to flip. Is this issue due to soft Oem 4 link bushings or because the pan hard is still out of geometry. I'm a long time reader but never post I'm glad to be joining the convo and appreciate the help I also added a pic
Old 03-21-2013, 06:52 AM
keg184's Avatar
keg184 keg184 is offline
Vehicle: 2012 dodge ram
Color: red
keg184 is on a distinguished road
If it is a vibration it is most likely you pinion angle is not correct. If you lowered it and did not rotate the rear axle to set you pinion angle to the correct degree you can get a vibration from the drive shaft.
Old 03-21-2013, 07:41 PM
hodgeee's Avatar
hodgeee hodgeee is offline
Vehicle: 2012 dodge ram 1500 2x4
Trim Level: express
Rep:134
hodgeee will become famous soon enoughhodgeee will become famous soon enough
I am taking into account that you did align it correct?
Otherwise, tons of us have lowered our trucks the same way, and I have heard no one else complain about this. I ran my truck to 120 a couple of times and smooth as silk, I have drag raced it also, and ran it on a 1.2 mile road course about 20 laps, and no issues. I would definately take it back to the alignment shop and check it out.
Your drivshaft alignment should be fine, even though you lowered it, with the 4 link arms, it keeps the rear end in the same angle of adjustment, wether it is maxed compressed or hanging down low from a lift!
BellTech 2/4 Street Performer, Spohn PanhandRod, Hellwig Sways, Volant Intake(Donaldson Filter), 85MM Fastman Throttle body, 14" Magnaflow, T1000 w/Hemifever Tune, 180 T-stat, 4.10 Gear Swap, Edge Street Perf - 2600 Stall, Billet Catch Can, E-Fan Swap, ARH LongTubes
Old 03-25-2013, 12:48 AM
Yes I aligned it properly. And no it's not a vibration it's a compleat shimmy in the rear end. I believe it is the bushings but remember I'm from Canada and live in Manitoba were are best roads would problly be considered shit to most of you guys
Old 03-25-2013, 01:28 AM
ONOutdoorsman's Avatar
ONOutdoorsman ONOutdoorsman is offline
Vehicle: 2012 Ram CC 1500 4X4
Trim Level: Outdoorsman
Color: Black (PX8)
Rep:388
ONOutdoorsman is just really niceONOutdoorsman is just really niceONOutdoorsman is just really niceONOutdoorsman is just really nice
Sounds like it could be the canuter valve.
Old 03-25-2013, 08:26 AM
hodgeee's Avatar
Trim Level: express
Rep:134
he he...............
Old 03-31-2013, 11:55 PM
Oh yeah or maybe the heffer jumped the bull shaft
Old 04-01-2013, 04:54 PM
keg184's Avatar
Color: red
Did you check your wheels, are they seated properly. Sometimes rust builds up on the center and the wheels do not seat against the hub properly.
Old 04-01-2013, 06:57 PM
oldhp's Avatar
oldhp oldhp is offline
Vehicle: 2014 Express 3.6/8 speed auto
Color: WHITE
Rep:902
oldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to behold
How much did you lower it? With bad/bumpy roads, it could be the rear axle beating against the bump stops.
I lowered mine 2" in the rear and if I hit a good dip in road I get the rear end hitting the bump stops.
2014 Express 3.6/8 speed/3.55 gears...Work Truck
2012 Equinox 2.4...Wife's Ride
"Life's hard, it's harder if your stupid."
How would you know?
Old 09-16-2013, 04:52 PM
Firehawk's Avatar
Firehawk Firehawk is offline
Vehicle: 2011 Dodge Ram
Trim Level: Express RCSB/2WD
Color: Mineral Gray Metallic
Firehawk is on a distinguished road
Send a message via Yahoo to Firehawk
Question
Did you ever get it figured out? Did you swap out the bushings for something else or was it the panhard bar needing to be adjusted?
Maybe try contacting the guy who posted this thread for help: http://www.ramforumz.com/showthread.php?t=140306
↑↑↑↑↑↑ My truck modifications list is located in my forum profile. → → →
