Old 03-21-2013, 07:47 AM
bandit1047 bandit1047 is offline
Vehicle: 1995 Dodge Ram 2500
Color: Green & Silver
Engine: 1994-1995 359ci (5.9L) Cummins 12-valve Diesel I6 175hp 420lb/ft(manual), 160hp 400lb/ft(auto)
bandit1047 is on a distinguished road
Question Brakes won't bleed
I just finished installing new front disc pads and since my Ram 2500 is a 95, I thought I would bleed the old fluid out and replace it with synthetic.
I flushed the system using a pressure bleeder and have clean fluid in the system, however, when I start the truck, the pedal slowly goes to the floor as I apply pressure. I purchased a Phoenix V12 pressure pump and reverse bled the brakes starting at the farthest wheel and worked my way up. Same problem; start the engine and pedal moves to floor when pressure is applied. HELP, I am at a loss since the brakes had no other issues than worn front pads when I started. Someone said I may have damaged the master cylinder when pumping the brakes since I pumped past the normal travel of the master cylinder when I first tried to bleed the system.
Old 03-21-2013, 08:16 AM
Rep:1882
If memory serves, you need a scan tool to run the bleed brakes function in the ABS module.
Old 03-21-2013, 02:42 PM
Default Bleed brake module?
What is a bleed brake module, where do I get one and how do I use it?
Old 03-21-2013, 02:44 PM
Default Scan Tool
Sorry, I meant what is a scan tool and how do I use it?
Old 03-21-2013, 03:19 PM
Rep:1882
A scan tool is a tool that connects to the vehicles computers and allows communication and bi-directional control. I strongly recommend you have the truck taken to a shop that has one and let them handle the procedure.
Old 03-25-2013, 07:50 AM
Default ABS disconect
Can I disconnect the ABS from the brake system? Will the brakes function only as if there is no ABS? I need to get it to a dealer for them to scan and set things I assume, however I live in the country and towing the vehicle is not CHEAP!
I assume the ABS is making the brakes act like they are not bled of air. I don't understand why that is going on.
I didn't think the 95 ram had ABS brakes.
Any ideas would help.
Old 04-03-2013, 09:48 AM
Gen1Ram Gen1Ram is offline
Vehicle: 1994 Dodge Ram 2500HD pickup
Color: Blue
Rep:17
Gen1Ram is on a distinguished road
my 94 has anti lock, i think just in the rear wheels tho....
Old 05-30-2013, 10:22 PM
green01sport green01sport is offline
Vehicle: 2001 Dodge Ram
Color: Green
green01sport is on a distinguished road
95 is obd1. Not a lot of things a scan tool can do for that.
Old 05-31-2013, 10:21 AM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
Try bleeding them again manually, except this time, once you crack the bleeder keep the pedal to the floor and count 10 seconds. Then tighten the bleeder.
Perform 3 more times.
It's a rudimentary ABS system and this is usually the only way to get it to bleed out correctly.
If that doesn't help, your front hoses may be bad.
