Old 03-21-2013, 10:36 AM
racerx37335 racerx37335 is offline
Vehicle: 2006 Ram 1500
racerx37335 is on a distinguished road
Default 2006 Head Gasket Replacement
Replaced head gaskets on 2006 4.7 (had blown gasket at cylinder #8). Marked chains put back exactly as marked (never removed chains completely from motor). i did remove front cover and made sure all gears remained in original positions (crank, idler, cams). Truck started and ran PERFECT for 30-45 seconds until I decided to tach it up a small bit. Truck had great oil pressure etc... As soon as I touched the throttle the engine began to ramp and then shut down just like it was turned off. Will now try to start and run only if u hold throttle flap wide open. Verified timing still correct at cams/crank. Verified 60 psi fuel pressure. Right bank plugs immediately turn to black soot. Left bank plugs remain pearl white but gassy wet. Next step is to pull front cover and re-time using the factory marked links. All sensors look normal on scan-tool. Any ideas? All help is appreciated.
Jeff
Old 03-21-2013, 11:20 AM
Rep:1885
If you've knocked off the timing, the intake valves can hit the pistons and bend. Did you tension the chains before starting the engine?
Old 03-21-2013, 02:49 PM
If the timing did indeed move, I can tell you that it is no more than a tooth at each cam. I really don't think the timing moved. I have already took valve covers off and with the balancer on the TDC mark, the V8 on each cam was as close to being straight up as possible. The aggravating deal is that the V8 mark on each cam is slightly to one side of the 12 oclock position, but if you were to move the cam a tooth, then it is slightly to the opposite side of the 12 oclock position. There is no spot for them to be perfectly at 12 oclock. Motor appears to have all kinds of compression and will run and smooth out (no popping back through intake etc..), but will not stay running for long.
Old 03-21-2013, 03:20 PM
Rep:1885
One tooth off is all it takes to bend the intake valves. Did you use the dots on the sprockets and plated links on the chains to time it?
Old 03-21-2013, 03:40 PM
I didnt take the idler and crank gear off. I left them in place and used a paint marker prior to disassembly and did use my paint marks to re-align on exact same teeth. I don't really think intake valves are bent because it runs very smooth for some short durations before it appears to flood out. It ran perfect for the first 30-45 seconds on the first crank. Any thoughts as to why soot on one bank and gassed up and white on the other? Could injectors be doing something crazy?
Old 03-21-2013, 04:41 PM
Rep:1885
Pretty unlikely unless they were commanded to by the PCM. The first thing I would do is verify the timing by pulling the front cover. You can have the balancer aligned, cams aligned and still be off on the crank sprocket.
Old 04-15-2013, 03:07 PM
The problem turned out being the cam pin sheared off on the left cam. I can only assume that I didnt get it tight. It bent all the intake valves on that head. Got the head fixed. I got the pin out and put in a new pin from Dodge and then torqued the bolt to 90 ft lbs using torque and spanner wrenches,and "loctited" it. The motor cranks and drives good but does some funny stuff at idle. Main thing I notice is the tach is reading reallllly low. Appears to be even lower than the motor is actually running. The truck will die sometimes and it sounds funny on initial cranking but cranks back up and runs fine. Truck runs good down the highway. It has set a CEL. I will try to scan it in next day or two. Any guesses as to what problem is? I did install an Autozone cam sensor when I had the initial problem. Wondering if that could be the culprit. Maybe CEL diagnostics will tell me. Will keep you posted.
Jeff
