Old 04-16-2013, 07:48 AM
ajd76's Avatar
ajd76 ajd76 is offline
Vehicle: 2015 Dodge Ram 1500 CC
Trim Level: Lonestar 4x4
Color: Max Steel
Rep:103
ajd76 will become famous soon enoughajd76 will become famous soon enough
Originally Posted by 32seventeen View Post
That thing looks cool, now I want one. I guess this doesn't replace the cable, or does it?
Nope. It just augments the existing cable. Easy mod and worth the money.
Old 04-27-2013, 09:01 AM
jmiller2308 jmiller2308 is offline
Vehicle: 2011
Color: Green
jmiller2308 is on a distinguished road
The best deal I found was the one I bought from Newegg for $29.60 shipped to the door.
The only issue I had was the washer under the cable connector was thinner than the one that came from the factory. This resulted in the metal part of the cable rubbing on the side of the box. I looked at reusing the factory washer but it wasn't going to easily separate from the factory bolt. I ended up putting another thin washer against the bed and the supplied washer to act as a ship and everything works now.
Old 06-22-2013, 07:12 PM
K-Bomb K-Bomb is offline
Color: Mineral Gray
Rep:16
K-Bomb is on a distinguished road
While I was installing my Tailgate Assist I had an issue with the nutcert. Called Dee Zee and the lady on the phone was really helpful. Within a matter of literally two minutes I had new nutcert on the way. Parts arrived two days later and not only did they send a replacement nutcert but also all the other misc parts that are included with a new shock. If only all customer service departments were this good.
Old 06-22-2013, 07:35 PM
K9ENDY's Avatar
K9ENDY K9ENDY is offline
Vehicle: 2013 Dodge Ram CC
Rep:175
Agreed, the are pretty darn awesome! And just to give credit where credit is due...AMI is pretty darn awesome, too!! If you ever need any if their products, they are wonderful to deal with.
Old 06-23-2013, 04:47 PM
RedSmart's Avatar
RedSmart RedSmart is offline
Rep:883
I found the hardest part of this was taking the washer off of the bolt, so I could take the limiter off!!
The nutsert was a bit of a pain in the butt, but once you figure that out it's smooth sailing.
For those of you that are having a hard time with the nutsert do this.
Measure your 3/4" on the nutsert and with a bright colour (paint, liquid paper) mark a small line onto the nut itself.
Insert the device into the hole and use your allen key to hold the screw part still. With your wrench, turn the nut clockwise no more than 9 turns of the white paint that you see on the nut.
When you have finished your 9 turns, then use your wrench to turn the nut counterclockwise until it becomes lose. Then use the allen key on the screw to take the device the rest of the way out.
I have to admit it took me a few seconds to get my head around how it worked, but once I figured it out it was simple.
Old 07-20-2013, 09:39 AM
Color: Mineral Gray
Rep:16
After having the tail gate assist on the truck for about a month I noticed its rubbing the paint off on the tailgate when closing. The top part of the shock rubbed a line in the paint down to the primer. Now I have to try to find some touch up paint and ditch the shock.
Old 07-20-2013, 09:25 PM
RedSmart's Avatar
Rep:883
I can't say that I have noticed any paint problems with mine yet. I will admit there is a bit of a catch when I first open the gate, but it hasn't seemed to cause any problems so far?
Old 07-20-2013, 09:48 PM
hemidon hemidon is offline
Vehicle: 2013 Dodge Ram 1500 CC 4x4
Color: True Blue Pearl
hemidon is on a distinguished road
I couldn't use the washer they supplied. The cable would rub the DZ when closed. It made it stick a little when I went to open the tailgate. Took off the washer and put on a thinner shim I had in the garage. Works perfect now.
Old 07-21-2013, 06:00 AM
Asur Asur is offline
Vehicle: .
Rep:4373
Had mine for over a year, no issues, no rubbing, no problems, love this product, saved the tailgate drop more than once.
Old 07-22-2013, 11:24 PM
Yumdinger's Avatar
Yumdinger Yumdinger is offline
Vehicle: 2013 Ram
Color: Black Gold Pearl
Yumdinger is on a distinguished road
So 7 days ago I called Dee Zee to inform them of the misfit Lift assist on my Ram. They indicated they would be sending me the Ford kit. Since, I have ordered and received a Bakflip from California and a Bed Rug from Missouri and BOTH have already arrived to me in Minnesota, in 3-4 days.
In 7 days I have yet to receive the Dee Zee, Dee Zee is in Des Moines, 4 hours from me.
If I were Dee Zee and I had this type of problem I think I would have at least express shipped the replacement. At this point I am just hoping I get something, anything, someday.
Really happy they admit they have a problem, NOT happy I have a scratched truck and NO replacement product yet. I talked to a guy not the supposed "Good" customer service rep others have reported.
