Old 03-22-2013, 12:07 AM
helibri helibri is offline
Vehicle: 2007 Ram 1500 4x4
Trim Level: sport
Color: silver
helibri is on a distinguished road
Default 07 ram 1500 4x4
hi my 2007 ram 1500 4x4 has a vibration cummig from the front end i can feel the shake in the center arm rest and coffey holders shake as well it comes on at 40km to about 55 km,it does not matter if its in 4x4 or 2x4 i also tryed turning off the motor in (N) the shake is still ther,it was at the shop the other day the techs looked at motor mounts,u-joints,ball joints and looking for play in the t-case ect.Heres the weird thing it only does it when im toeing my 2200 lbs boat, soon as i am not toeing the boat the truck runs 100% normal.I pulled my boat all summer last year with no isues what so ever and my shop spent 4 hours trying to figure this out any help would be great.thanks
Old 03-23-2013, 12:30 PM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
Are you sure the problem is not with the boat (trailer) and being resonated through the hitch? Have you tried pulling a different trailer or having your boat towed by a different truck?
brad
Interested in one of my mods?
Old 03-26-2013, 12:18 AM
Trim Level: sport
Color: silver
Default vibation
thanks for the reply,the techs are saying the trailer should not be causing the front end woble ,the want me to load the bed up with 600 lbs of sand bags and see if its does it under load or pulling,but your right i should toe another trailer or have my friend toe my boat.thanks
Old 04-07-2013, 08:49 PM
Trim Level: sport
Color: silver
Default vibration
after toeing the boat with 4 other trucks all trucks seam to shake,anyhow its the tires on the trailer,one tire has bearing play and both tires were over inflated.
Old 04-08-2013, 10:12 AM
brad12kx's Avatar
Rep:2581
Trailers often end up with bearing and tire issues due to neglect. This is NOT a premeditated effort by the owners, but rather a normal occurrence with an item that sees minimal use.
My work trailers are used all the time so see very regular maintenance. My little utility trailer/golf cart trailer sees very little use and gets maintained every time something goes wrong with it. Yah.....not a maintenance schedule to be proud of.
brad
Old 04-13-2013, 12:40 AM
Trim Level: sport
Color: silver
thanks i will now pay attention to the trailer fro now on
