Old 03-22-2013, 08:59 PM
NewYorkNeanderthal NewYorkNeanderthal is offline
Vehicle: 2001 Dodge Ram 1500
Color: Dark Green
NewYorkNeanderthal is on a distinguished road
Default Truck shaking extremely hard at 60+ MPH.
Whenever I drive my truck and hit around 60MPH (100KMH) it begins to do this unbelievable shaking to the point where you can hardly see properly inside like the speedometer for example. Sometimes it shakes harder than others, but I've had it shake so hard that it's come right out of 4WD and I had to pull it back in. I've also noticed that it depends on the surface of the road sometimes as well, like certain stretches it'll do it a lot more intense than others. When it's under 60MPH it drives perfectly. There's no shaking and it's like any other vehicle. Any ideas on what's causing this and how to fix it or reduce it atleast would be appreciated. Thanks.
Old 03-22-2013, 10:17 PM
elinmon1976's Avatar
elinmon1976 elinmon1976 is offline
Vehicle: 2004 Ram 1500 quadcab 2wd
Color: tan
Rep:65
elinmon1976 will become famous soon enough
I would have the alinment checked and adjusted if need be first. You didn't say if you had done that or not and also it is possible that a weight has flung off one of the wheels so that it is out of balance.
2004 Quad cab 2wd 4.7L
1998 Ram Reg Cab, 5.2 auto 2x4
Flowmasters to make her rumble...LOL
Old 03-22-2013, 10:29 PM
Bully's Performance's Avatar
BULLYS PERFORMANCE
Vehicle: MOPAR
Rep:931
I agree check the alignment and have your tires rebalanced and then let us know if you are still getting the vibration/shaking.
Thanks
Jeremiah
Discount Auto Performance
Old 03-22-2013, 11:54 PM
Trim Level: SLT & Sport
Color: 1 Blk,1 Red
Rep:36
I'd say the double cardan joint on the front driveshaft is all done. a quick grab to check for slop in the rear of the front driveshaft will confirm. Zero slop/ play allowed. If you are somewhat handy and have a torch available, it is a relatively simple job to overhaul the ballsocket assy. change the 3 u joints at the same time, and save yourself some future grief. OR simply go to a driveline shop and buy a rebuilt driveshaft, they'll want the core for rebuilding.
Old 03-26-2013, 07:09 PM
igotit igotit is offline
Vehicle: 98 ram 1500
Color: blue
Rep:39
igotit is on a distinguished road
Send a message via Yahoo to igotit
almost sounds like death wobble to me....common on solid axel 4x4's.
http://www.kevinsoffroad.com/dodge-w...-causes-cures/
http://www.kevinsoffroad.com/how-to-...-death-wobble/
Old 03-26-2013, 07:47 PM
polecat327 polecat327 is offline
Vehicle: 99 ram 2500
Color: purple
polecat327 is on a distinguished road
Sounds like death wobble to me also , its very common on the dodges, track bar links are loose , gets yourself the lukes link kit and youll be amazed just ordered a set for my 99 2500
Old 04-17-2013, 04:26 AM
01-RAM-IT 01-RAM-IT is offline
01-RAM-IT is on a distinguished road
i just had this same issue. i had a misfire in #5 and once i took care of that the wobble went away.
Old 04-17-2013, 04:37 AM
Color: Dark Green
That sounds like a nightmare. Although it must've been glorious to have it gone finally. I guess that's only another thing I should check for now.
Old 04-17-2013, 07:46 PM
Color: blue
Rep:39
im sure hes kidding.theres noway a cylinder misfire will cause the issue you described.
a misfire woold cause engine rpm to shudder....but has nothing to do with the suspension system.
