Old 03-23-2013, 11:47 AM
roys ram roys ram is offline
Vehicle: 1996 dodge ram 1500
Color: green over silver
roys ram is on a distinguished road
Default help with audio
yo guys and gals i just installed a full set of kickers in my 1996 ram 1500
i installed 5.25 kickers in the back and installed some kickers ds693 3-way 6" x 9" car speakers i was woundering if i should install (kicker)ks13 crossover to them i am still going to install the dual 300watt amp with a 15" kicker comp as soon as a build the box but idont know if i can or should install the crossover pleasehelp ohh the all runing off a boss dvd head unit (radio)
Old 03-23-2013, 01:22 PM
Scotty85's Avatar
Scotty85 Scotty85 is offline
Vehicle: 2012 Dodge Ram
Color: True Blue Pearlcoat
Rep:79
Scotty85 will become famous soon enough
Almost all 2 to 3 way speakers that are integrated into one speaker (coax, 3-way) will have their own built-in crossover. I would leave it like it is for best performance. The only time you need to add crossovers is when using separate components.
If you're really looking to get the most out of a 2 or 3-way, you could cross them over just above where their frequency response starts (high-pass) with about a 12db slope. That way you won't be pushing too much in the low freq range to them and they'll run more efficiently. Most higher-end amps have crossovers built-in for this purpose. That, and the head unit may have it as well. If they both have this feature, only use ONE of them, and run the other as a pass-through (no crossover).
Scott
2012 RAM Sport CC Hemi - Photos here:http://www.ramforumz.com/showthread.php?t=132968
Audio Mods - http://www.ramforumz.com/showthread.php?p=1005034
Perf. Mods - http://www.ramforumz.com/showthread.php?p=1005080
Body Mods - http://www.ramforumz.com/showthread.php?p=1005083
