Old 03-23-2013, 06:28 PM
99ram2wd 99ram2wd is offline
Vehicle: 1999 dodge ram
99ram2wd is on a distinguished road
Default rearend problems
Im new here and i cant figure out where the noise is coming from in my rearend. Ive taken the cover off and there is no noise coming from in side but when you turn the wheels you can hear a grind/howl noise coming from the sides. is it the bearings? There is alot of shavings in the bottom but all the teeth look good. Never really messed with a rearend so have no idea. So any help would be appreciated
Old 03-24-2013, 09:41 AM
Rep:1909
I can about guarantee the pinion and side bearings are toast. If you replace them before they can cause any damage to the ring and pinion, you'll save yourself several hundred dollars.
Old 03-24-2013, 02:02 PM
Thanks for the reply. im going to pull the axles and see what the bearings look like.
Old 03-24-2013, 02:19 PM
Rep:1909
You'll need to take down the entire rear end to see the pinion bearings.
Old 05-27-2013, 10:51 PM
hvacunc hvacunc is offline
Vehicle: 2007 Dodge Ram1500
Color: burgandy
hvacunc is on a distinguished road
I have the same problem, just as I went over 100k. going to take to mechanic to solve problem
Old 05-29-2013, 02:29 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
Jack up the rear wheels and move them up and down (pry-bar underneath) to look for movement. Just about any movement will indicate a worn axle bearing. You can also look for moisture on the inside of the tire to indicate the axle bearing has been moving and caused the seal to wear.
Usually an axle bearing will produce a rhythmic hum while driving.
The pinion seems to make more noise on deceleration as when you let off the throttle.
