Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Powertrain > 5.9L V8 Specific Topics
Old 03-23-2013, 07:50 PM
Cheesewiz Cheesewiz is offline
Vehicle: 2007 Dodge Ram
Color: silver
Cheesewiz is on a distinguished road
Default Power Steering issue
Hey everyone,
I have a 91 Dodge 250, 4 wheel drive, radial transmission, 5.9 cummins.
The power steering went out but it's not howling or making any noise. If you put in fluid it will puke it out and push it out of the filler. Not sure if the pump is no good or if the steering box went out. Any ideas?????
Old 05-26-2013, 06:48 PM
eckoview05 eckoview05 is offline
Vehicle: 1985 Dodge W350
Engine: 1981-1988 360ci (5.9L) LA V8 170hp
eckoview05 is on a distinguished road
I would say the pump is the problem. I would lift the front end up and turn the wheel with the vehicle off to see if the steering gear is locked up.
Old 11-12-2013, 11:35 AM
GEN1's Avatar
GEN1 GEN1 is offline
Vehicle: 1993 Dodge W350 Dually Flatbed
Color: many, camo, black, red,
Engine: 1989-1993 360ci (5.9L) Cummins diesel I6 160hp 400lb/ft
GEN1 is on a distinguished road
Default power steering issue
I had the same issue on 93 w350 back in feb. swapped the pump and fixed it the issue..... until about 2 weeks ago and started doing the same thing, swapped it again, looks like it is working, both pumps were reman'd from oriely's. still waiting to see if anyone else has any ideas on any other issues that may causing this.. (see my previous posts)...
Old 12-24-2013, 02:03 PM
AaronR84's Avatar
AaronR84 AaronR84 is offline
Vehicle: 1984 Dodge D150 SWB
Trim Level: base
Color: blue
Rep:31
AaronR84 is on a distinguished road
i had that same issue last year with my 84 d150 and after replacing it with a new one i found that somehow trash of some kind had gotten into it and was clogging the pressure outlet and when i replaced it that took care of the trash in the pump but there was still some left in the hoses and it clogged up again. i had to flush the whole system and that finally solved the problem and i was able to put the original pump back on, this may not be your problem but its worth looking into i think. good luck with it
