Old 03-23-2013, 11:30 PM
ONOutdoorsman's Avatar
ONOutdoorsman ONOutdoorsman is offline
Vehicle: 2012 Ram CC 1500 4X4
Trim Level: Outdoorsman
Color: Black (PX8)
Rep:388
ONOutdoorsman is just really niceONOutdoorsman is just really niceONOutdoorsman is just really niceONOutdoorsman is just really nice
Default PAC LC-1 finally found a home
After living with my PAC LC-1 bass level control knob sitting in the centre console map pocket for a few months I decided to finally find a permanent home for it and the wires running to the amp behind the rear driver seat.
I was debating on installing it in the following locations:
1. Top row of switches above HVAC controls. The entire unit is sealed so no easy way to add a control.
2. Bottom row of switches (completely empty - where it says Ram) below the HVAC controls. The control knob electronics are too big to fit. Even if I removed the housing the circuit board is too big.
3. Shifter access panel above map pocket in centre console. No matter how I placed it the wires would interfere with the shifter cable.
4. Radio / HVAC bezel. Either drill a hole below 4WD knob or drill a hole in the centre of the bezel below the bottom row of switches. I really didn't want to drill a hole in the front of the bezel.
Decided on this spot.
There is a nice access hole in the bezel to run the wires.
I had to drill a couple of pilot holes for the 2 mounting screws but it's underneath and you can't see it. I feel a lot better now. No more wires hanging around and running under the floor mat in the rear.
