Old 03-24-2013, 01:09 AM
toolfreak101 toolfreak101 is offline
Vehicle: 2005 dodge ram
Color: silver
toolfreak101 is on a distinguished road
Default Iac and tps cleaning
wanted to clean my iac and tps sensor this weekend and was wondering what to clean them with.
for the tps i was told use throttle body cleaner but not sure for the Iac.
just wanted to know what are your thoughts.
Old 03-24-2013, 10:36 AM
Rep:1845
TPS sensors do not require cleaning and trying to do so would likely result in creating a problem. The throttle body and IAC are what typically needs cleaning out and you can find a basic tutorial here. http://www.ramforumz.com/showthread.php?t=46454
Old 03-24-2013, 09:07 PM
Color: silver
this may sound crazy but how do you remove the electrical connection from the IAC.It has a red tab on it .Just not sure how to remove it without breaking it.Makes it easy to remove the screws holding the IAC to the throttle body
Old 03-25-2013, 08:59 AM
Rep:1845
The red tab is called a connector position assurance lock and it needs to be slid back to disengage the connector release.
Old 03-25-2013, 03:05 PM
Color: silver
after i slide the red tab back does the connector slide off
Old 03-25-2013, 03:15 PM
Rep:1845
Depress the release under the red lock and slide the connector off.
Old 03-25-2013, 09:37 PM
Color: silver
ok i will give it a try.thank you
Old 03-27-2013, 01:42 AM
Robgotti's Avatar
Robgotti Robgotti is offline
Vehicle: 2008 Dodge Ram
Robgotti is on a distinguished road
For cleaning Mopar brake cleaner is what I heard from someone
But ha not shade chance to really research
Old 03-27-2013, 09:08 AM
Rep:1845
It depends on the application. Older cable operated TB's can be cleaned with carb cleaner, specialty TB cleaners or brake cleaner. Newer electronic throttle bodies need to be cleaned with ONLY brake cleaner.
Old 04-01-2013, 01:49 PM
snrusnak's Avatar
snrusnak snrusnak is online now
Rep:1385
You can also use electronic parts cleaner(can get at radio shack, etc).
Sean
