Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
Old 03-24-2013, 02:52 AM
renman1972's Avatar
renman1972 renman1972 is offline
Vehicle: 1985
Trim Level: Base
Engine: 1981-1987 318ci (5.2L) LA V8 140hp
renman1972 is on a distinguished road
Default Flickering Electrics
Hello All,
I am the proud owner of a 1985 D150 base model with a 318 in it.
For some reason my lights (all of them) flicker when the truck is at idle.
It is so bad that at a red light, my radio cuts off from lack of power it seems.
I don't know if its the voltage regulator or the ECM or what.
Help PLEASE!!!!!
Old 03-24-2013, 09:33 AM
Resident Technician
Rep:1915
It's hard to say without performing some basic testing. Is the battery the correct one and does it pass a load test? Are the terminals clean and tight? Are there any voltage drops between the battery and alternator, regulator or engine block? What is the regulated and unregulated output of the alternator? Are the alternator belts properly tensioned and not slipping?
Old 03-24-2013, 10:24 PM
pwrman pwrman is offline
Vehicle: 2008 1500
Color: Blue
Rep:12
pwrman is on a distinguished road
A few simple testes with a volt meter will tell the tale. You can pop the battery and the alternator out and take them to your local Autozone, Pepboys etc and they usually test them for free. Before you do that, check all the connections for clean and tight, that is were I would start.
Old 05-18-2013, 10:44 AM
86whiteram 86whiteram is offline
Vehicle: 86 Ram d100
Trim Level: basic
86whiteram is on a distinguished road
i have the exact same problem with my 86 put a new regulator and battery and still has the problem
Old 05-18-2013, 09:08 PM
crazzywolfie crazzywolfie is offline
Vehicle: 81 91 93 dodge
crazzywolfie is on a distinguished road
sounds like you need to check what the voltage is with the truck running. with old trucks bad connections is a common problem. could be a bad ground connection.
91 & 81 d150 carburated 318's 93 R.C. F.I.318
