Old 03-24-2013, 03:40 PM
jcmorozz jcmorozz is offline
Vehicle: 2003 Dodge Ram 2500 Quad Cab
jcmorozz is on a distinguished road
Default 2003 2500 Not Turning Over
The engine is not turning over, no engine rotation what so ever.
This is not be expertise so I'm hoping someone can point me to the right direction. The battery has been checked and doesnt seem to be the issue (My lights, etc are work fine and the lights arent dimming when starting)
Around two months ago, I noticed the ground terminal had exhibited a large amount of corrision which i cleaned with the battery cleaner and coated. I didn't have any issues really after that till a month later it took several attemps turning the key to turnover, i again checked the ground terminal and recleaned/coated it. It has been firing up a little rougher then when i first bought the truck but nothing major. The other night i got nothing when turning it over. I checked the terminal and noticed the bolt had actually corroded in half and the body ground (attaches to left fender and directly to terminal) was loose. I got it roughed in there and held, after around half hour of denking with it, it fired up out of the blue, i got it home and immediately after cutting the engine, it was back to not firing.
I contrubited this to the ground terminal so just replaced it all together with an aftermarket bronze, wire brushing all connections, etc. Same issues. Im assuming it is my starter and it just happened to be around the same time as my ground terminal issues. Im going to get a voltameter now..
Pretty much I'm hoping someone with experience can help diagnose this with the simply fact the truck was a little rougher over the last month starting and then after continually trying to fire it up, it was able to once.
Old 03-25-2013, 08:34 AM
tjbiker031's Avatar
Vehicle: 2002 Dodge Ram
Trim Level: SLT - Quad Cab
Color: Graphite Metalic
Rep:118
Start by checking grounds for battery and starter. Make sure you are getting voltage to the starter during start-up. Do you have any DTC's (codes)?
Old 03-29-2013, 09:21 PM
Still no luck
Replaced Ground Terminal
Replaced Battery with new Optima (it was exhibiting unusually signal), it was working but had one dead cell?
Benched Tested Starter - Good
Removed BullyDog Tune
No DTC Codes (Ground was pulled so i wont get any more codes but it has had a P0440 which is an emission system before)
Checked all Fuses, Relays
Only thing left would be a circuit or transmission relay issue?? Could it be the computers fried or the engine issues?
Old 03-29-2013, 10:24 PM
ohh yeah and earlier when i was messing with it, i was turning the ignition over and over and it finally turned on, it was sputturing and idling very rough (like the truck shaking). I turned it off and it turned back over twice more then back to nothing again.
