Old 03-24-2013, 03:03 PM
KA1OTE's Avatar
KA1OTE KA1OTE is offline
Ram Ham
Color: Mineral Gray Metallic
Rep:1475
Default Changing the map lights
I tried searching for this but apparently 'map' is removed from my search
I have new LED bulbs for my map lights and need to know how to swap them with the factory lights on my 2012. I've found a couple of resources on the web, but none of them look like mine (I've removed the covers). All of them differ in the setup and/or bulb placement when compared to what I see in my truck.
Any help would be appreciated.. I'm really hoping to get these installed today as it doesn't seem difficult.. thanks!
Old 03-24-2013, 03:45 PM
ONOutdoorsman's Avatar
ONOutdoorsman ONOutdoorsman is offline
Vehicle: 2012 Ram CC 1500 4X4
Trim Level: Outdoorsman
Color: Black (PX8)
Rep:388
ONOutdoorsman is just really niceONOutdoorsman is just really niceONOutdoorsman is just really niceONOutdoorsman is just really nice
I've read that others had put zip ties at the base and pulled on them to get them out. I used a pair of needle nose pliers to pop them out. You need to pull straight down but they are tight and it's very hard to get a good grip.
Old 03-24-2013, 04:18 PM
KA1OTE's Avatar
Ram Ham
Rep:1475
Zip ties and needle nose pliers.. hmm... thanks for the suggestions! I will give those methods a try!
Old 03-24-2013, 04:25 PM
Color: Black (PX8)
Rep:388
I got the pliers in at the base of the bulb and wedged them out. I covered the ends of the pliers with a shop towel. I did not squeeze the main part of the bulb and try to pull down. A few members have had bulbs break because of this and it creates a big mess as well as a danger to your eyes.
Old 03-24-2013, 05:59 PM
viperr817's Avatar
viperr817 viperr817 is offline
Vehicle: 2012 ram
Rep:195
viperr817 has a spectacular aura aboutviperr817 has a spectacular aura about
i used needle nose pliers with fingers from a rubber glove over the bulb. The front push lights pry off from each side towards the hood. Be careful removing them and re installing the rear has a tab that activates the switch. the rear light has a nothch for a small screwdriver i believe on the driver side.
Old 03-25-2013, 03:56 AM
KA1OTE's Avatar
Ram Ham
Rep:1475
Thanks for all the ideas and feedback everyone. Husband ended up using a string and kind of 'lassoing' the base of the bulbs and out they popped! Worked like a charm.
