Old 03-24-2013, 07:03 PM
Danimal77's Avatar
Danimal77 Danimal77 is offline
Vehicle: 2015 RAM 1500 CREW
Color: Maximum Steel Metallic
Danimal77 is on a distinguished road
Default 295/60 and 20x10 -19 fit ?
I have the oppurtunity to purchase a set of Nitto Terra Grappler's from a buddy. He needed to sell his truck because of a job change and no longer needs the tires. Brand new never mounted 295/60/20. I believe these measure around 34.5" x 12ish".
I want to run a 20x10 wheel with a -19 offset. I will use Bilstein 5100's set at 2.1" and probably get a Zone 1.5" body lift. May also add a small rear 1" coil spacer.
I know there are guys running 20x10 -24 with just a 2.5 front spacer with no rubbing. I'm just looking for a little reassurance from some of you guys that are more in the know than I.
The wheels I want are the 2 piece Fuel Nutz in black.
Thanks for any help!
2015 RAM 1500 Sport CC 4X4 Maximum Steel Metallic
Old 03-24-2013, 07:11 PM
Danimal77's Avatar
Sorry....truck is a 2012 1500 4x4
Old 03-25-2013, 01:10 PM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2026
I know a 20x10 -12 offset with 35x12.5's will fit with a 2.5" leveling kit. So I'm sure with your Bilsteins at 2.1" and a 1.5" body lift you shouldn't have a problem.
Old 03-26-2013, 01:31 AM
Exactly what he ^^^ said
Old 03-26-2013, 02:38 PM
TNhemi12 TNhemi12 is offline
Vehicle: 2012 Dodge Ram
Color: Mineral Gray
Rep:18
TNhemi12 is on a distinguished road
LUCKY!!! I've been looking for that exact tire on craigslist forever, finally bite the bullet and ordered some new. Getting them installed Thursday. I have a 2.5" level, 1.25" body lift and my wheels are only a +1 offset. You should clear everything easily.
Old 03-26-2013, 04:56 PM
Just an FYI guys.....
As of this week we can now get wheels and tires and offer them at very competitive pricing. If not, better than most you see out there
Old 03-27-2013, 12:07 AM
Danimal77's Avatar
Any of you guys know how far a -19 offset will stick out past the fender?
Old 03-27-2013, 10:28 AM
Color: Mineral Gray
Rep:18
Check out this website, helped me when making a decision.
http://www.rimsntires.com/specs.jsp
Old 03-27-2013, 02:29 PM
Stock wheels are +19, so you are moving it out 38mm, that is 1.5"
