Rear end whine? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
Old 03-24-2013, 09:04 PM
elinmon1976's Avatar
elinmon1976 elinmon1976 is offline
Vehicle: 2004 Ram 1500 quadcab 2wd
Color: tan
Rep:65
elinmon1976 will become famous soon enough
Default Rear end whine?
The whine sounds like it is coming from the right rear wheel. I thought it was the rear end, the a wheel bearing. Problem is, I have NEVER tried to take a rear end down and I don't even know how to do this. What bearing is in there? would it be an axle bearing?
2004 Quad cab 2wd 4.7L
1998 Ram Reg Cab, 5.2 auto 2x4
Flowmasters to make her rumble...LOL
Old 03-25-2013, 08:22 AM
Resident Technician
Rep:1915
This will most likely be a pinion or differential side bearing problem. If you haven't torn down a rear end before, you should either have it done or at least make sure you have experienced help to guide you.
Old 03-25-2013, 09:53 AM
Color: tan
Rep:65
I have a buddy that may be willing to help. I swear, sometimes I just want to set this truck on fire...
Old 03-25-2013, 10:02 AM
Resident Technician
Rep:1915
Rear end bearings in these trucks are known to be something of a weak link, especially if they're old and/or neglected.
Old 03-25-2013, 10:18 AM
Color: tan
Rep:65
I bought this truck with about 180k on it, so at this point, I'm just trying to get it to hold together. I know the next thing will be the front end. Bushings and ball joints are pretty worn. I'm just getting really tired of working on the old girl... But those are the breaksas they say.
Old 03-25-2013, 10:34 AM
Resident Technician
Rep:1915
At this point, it sounds like you can get away with replacing the bearings and seals. Gear damage is pretty rare with just a simple bearing failure.
