Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
Old 03-22-2013, 05:16 PM
ben.kirk ben.kirk is offline
Vehicle: 1997 Dodge Ram 1500 5.2
Color: Green
ben.kirk is on a distinguished road
Default Motor swap need help
My truck blew the motor, I believe it spun a bearing then broke a connecting rod and blew a hole through a piston. I bought a 318 from a '99 1500. Wisdom
Question I have is, can I direct swap my '97 318 over to the '99 318? If not, what parts or pieces will I need to transfer or buy to make it work correctly? Any and all help is greatly appreciated. I should add, I'm planning on doing this tomorrow.
Old 03-22-2013, 05:20 PM
Rep:1915
You shouldn't need to do anything but transfer existing parts from one engine to the other.
Old 03-22-2013, 05:24 PM
Color: Green
That's what I thought, but I was given the full wiring harness off of the '99 and the fuse box isn't the same, as in its bigger and has more to it, and the alternator on the '99 is a plug in style. Just want to make absolute sure that it'll be a smooth transfer.
Old 03-22-2013, 06:00 PM
Rep:1915
Just do a typical long block swap and you should be fine.
Old 03-23-2013, 03:10 PM
Color: Green
Consisting of what exactly? I bought a high volume oil pump, motor oil, power steering fluid, oil pan gasket and some cleaners for the motor.
Old 03-23-2013, 05:53 PM
Rep:1915
Swapping over the needed parts from the existing engine to the donor.
