Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Electrical
Old 03-24-2013, 09:12 PM
ljohnlevy ljohnlevy is offline
Vehicle: 2009 dodge ram 1500
Trim Level: sport
Color: maroon
ljohnlevy is on a distinguished road
Angry Drivers side door lock problem.
Hello drivers. I am having a problem with the drivers side door lock not opening or closing with the key fob. The other 3 doors are fine. Any suggestions would be appreciated.
Old 03-24-2013, 09:36 PM
Grubrunner's Avatar
Rep:3883
It appears that side's actuator is not working which could be because of several things.
If you have a little DIY savy, you can check the wires thru the door jamb for pinches or, better yet, pull off your door trim to inspect inside the door skin for a loose actuator arm/rod. It may even be the module that is the brains of the central locking that could be mounted anywhere; though I highly doubt it's mounted inside the door panels.
Like I said, it could be a number of things....
A dealership visit OR a reputabler car audio will resolve the issue by pinpointing the source.
Good luck.
Grub out!
