Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > V10 Specific Topics
Old 03-24-2013, 11:53 PM
Lordtunaboat Lordtunaboat is offline
Vehicle: 1996 Dodge Ram 2500 V10
Lordtunaboat is on a distinguished road
Default V10 maintenance
Hey so I looked in the owners manual and the service manual for my truck (96 2500 v10 4x4) I wanted to make sure everything was up to date. I noticed that there didnt seem to be anything other than plugs, wires, air filters, and fluid/filter changes for my motor. The manual has you do checks and replacements on other engine parts but only for the 5.9. (EGR PCV, ect..)Does anyone have a thought?
Old 03-25-2013, 07:45 PM
99 V10 99 V10 is offline
Vehicle: 1996 SLT
99 V10 is on a distinguished road
If that isn't enough you can do mine.LOL Sounds about right.
Old 05-10-2013, 11:13 PM
James Posey's Avatar
James Posey James Posey is offline
Vehicle: 2001 3/4 ton 4x2 5.9 Cummins
Color: White/Silver
Rep:13
James Posey is on a distinguished road
Default Factory Service Manual
I downloaded a factory service Manual for my 1998 for less than $20 bucks from ebay. PDF format. The real deal. I saw one for 2001 Ram also.
JP
Old 06-09-2013, 01:57 AM
Pman's Avatar
Pman Pman is offline
Vehicle: 1996 Dodge Ram 3500 Dually V10
Engine: 2003-2003 488ci (8.0L) Magnum V10 310hp 450lb/ft
Pman is on a distinguished road
You are going to want to grease your Zerk fittings on all suspension components, your drive lines and while you are down there, look around for things that seem a miss. loose wires, frayed cables, rust, loose bolts and any leaks. If you feel Ram-bunctious, check out your brakes and tires (air pressure and wear).
